Question about Fedders A7DH45B2A Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked for nearly 12 years.
    Scholar:
  • 117 Answers
Coolant may be low - warranty should be 5 years
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Posted on Jan 06, 2010
SOURCE:
I have a brand new dehumidifier (properly sized) that is running 24 hours/day and producing some water (roughly 1L).
with a reading of 66 to 67 % rh this is a bit low for normal rooms humidity , I cant see why you'd want to try to get it down to 55% unless its for a special purpose (drying paint?) , I get this question a lot from folks , what I tell em is if you set your airconditioner in your home down to 30 degrees would your house ever get that cold = "no " the houses ability to heat itself is greater than the a/c units ability to cool it (even if its properly sized) so why would you expect a small appliance like a dehumidifier to be able to do any different ? all you end up doing is over working the appliance and costing you extra money in lost power
the general excepted room humidity is 70% rh this is a industry standard ,that all appliances are designed to achieve , and yes as the room gets dryer it will extract less and less water from air
Jul 29, 2015 | Dehumidifiers
Tip
Taking the Confusion Out of Using a Dehumidier
Many consumers are confused about setting the proper levels of humidity on dehumidifier units. And then think something is mechanically wrong with the unit. When in fact, over 70% of the time it operator error. That and a lack of proper routine maintenance are the problem.
The numbers on the LED screen represent the amount of humidity you want to maintain. Not the amount you want to remove. For example: If you set the level at 70%, which is rather high, more than likely the unit may start up momentarily and then shut OFF. That's because the setting is to high. Now, if you set it at 45%, the unit will turn ON and run until either the bucket is full and/or the humidity level has reached 45%.
Here's a good rule of thumb if you use your humidifier year round.
In the Winter you want to maintain a humidity level of 50 to 60%. The moister the air, the more comfortable it will feel. Plus, the humidity helps eliminate static electricity in the air.
Conversely, in the hot, humid Summer months, you want to keep the humidity level as low as possible (35% or less). Also, if you have ceiling fans, using them 24 hours a day, helps to move the air and generate a windchill, which fools your body into thinking it's cooler than what it really is. At the same time, it's saving on energy costs by not having to run your AC as much, because the dehumidifier is removing the humidity.
Just remember, the higher the setting, the higher the humidity level will stay. The lower the setting, the more humidity will be removed and the more comfortable you'll feel in the Summer.
And don't forget Routine Maintenance. Clean the air intake filter regularly. Clean and wipe down the refrigerant coils every 60 days. And don't allow water to remain in the collection bucket to long. As mold can build up in it.
Speaking of which, the water in the bucket, when fresh, is great for watering house plants. Because, when it's fresh, it's distilled water. No chlorine or minerals.
on May 04, 2011 | Maytag M7DH45B2A Dehumidifier
I bought the FriedrichD50. It worked fine in 2 weeks with the built in pump. After I disconnected the drainage by using the bucket, no water comes out. Does it make sense the machine runs 2 days straight...
Yes, it does make sense, depending on what humidity extraction level you have it set on. Set to high, it will will remove little to low condensation/humidity. Set it to 35% or if you have an analog model (no LED screen) set the humidity extraction knob on Maximum Also, be sure that the air intake filter is clean.
Thanks for choosing FixYa.
Sep 19, 2011 | Friedrich D50C Dehumidifier
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
My dehumidifier is not collecting water what can i do to fix it? the model #99701
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 primary reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Kenmore 54501 Dehumidifier
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
Machine runs, but no water is coming out into the bucket
Jun 02, 2011 | LG LHD459EL Dehumidifier
Didn't LG produce some bad Humidifiers several years ago and have a recall on not working units? I recall reading this in Consumers Reports. I bought one back then and it has not produced a drop of...
If has not produced a drop of water for several years, then it's not working properly. But, this may be a case of setting the humidity level to high. In other words, if you set it at 70% or Maximum, that's the humidity level that it will maintain, not remove. To remove humidity, the level must be set low (35% or Minimum).
To test the unit, based on what I just said, place it in the bathroom, set the level as low as possible and turn the shower on medium hot. Do Not turn the bathroom exhaust fan ON. As you leave, close the bathroom door. Return in 15 minutes, turn the shower OFF and check the bucket water collected. If there's any water in it, it's working fine. It was probably a case of the humidity level being set to high.
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | LG DH305 Dehumidifier
My humidifier dont collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Maytag Dehumidifiers
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
519 people viewed this question
Top Fedders Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
dadr
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
