When i start my Hotpoint Aquarius WDL520 it goes through the motions of starting(i.e. the door lock mechanism engages), then after a period of 5 or so minutes all the lights start flashing yellow rapidly.The washing maching then empties. The drum does not rotate at all. I have enquired to hot(pants) and they say its a problem with the computer. Its now 14 months old with a 1 year manufacturing warrenty. Basically what i can tell from other websites it may be a problem with the PCB??? I take that this is the issue and needs replaced. Can anyone please tell me if thats right and if so how to replace it? Thanks Billy
  • 3,741 Answers
Yes exactly---
you are right the faulty control board causes this issue.
But initially check this:--remove the hotpoint washing machine top and the control board cover from the door, check if the wiring cables are damaged as they are run through the door hinge .maybe one of the wires are loose that enters in the terminal plug, if yes then reconnect the wire and test.
you can buy parts from.:--
http://www.espares.co.uk/part/washing-machines/hotpoint/p/1085/808/0/0/715149/washing-machine-pcb-(prin.html
http://shop.ukwhitegoods.co.uk/Washing+Machine+Parts/Hotpoint/Timers+and+Modules/otpoint+Washing+Machine+PCB+Control+Board.html
sometimes the parts are not in stock with them as your model is bit rare but you can contact them through their contact numbers and place a order.they will arrange it normally.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Dec 10, 2009
Hotpoint wdl520 aquarius not switching on!
hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Jan 01, 2014 | Hotpoint Aquarius WD63 Front Load...
Door locked light is flashing hotpoint aquarius washing machine wont start
More than likely the door mechanism is faulty and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Hotpoint Aquarius WD640 Front Load...
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Hi, I have a Hotpoint Aquarius 7kg WDL520 washing machine. I have just went to open the door to hang out a wash I did earlier. The door is locked and no power seems to be in the washing machine as...
Does it have a separate drawer for the detergent and softener? sometimes opening that will unlock the door. It sounds like it was overloaded and blew an interior circut
Oct 21, 2010 | Washing Machines
I have hotpoint wma62 and door lock light flashes, machine will not start as door will not lock any clues ???
Hiya,
yes, i can help..
Firstly, lets start simple. Have you noticed the door lever/handle has got "floppy"? or loose? or easy to squeeze?
This is the most common reason, what happens is there are 2 bits of spring steel behind the handle, these either break or become weak, to test this theory, close the door, put your finger between the handle and the door and push the handle towards the glass, if this works then you need a new spring/handle.
Please let me know,
Please rate my help.
Regards
Sussex engineer.
Oct 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint won't start
If no lights showing at front of m/c, then I would suspect door lock not engaging
Dec 02, 2008 | Hotpoint Aquarius WD63 Front Load...
How to get access to door interlock mechanism?
IT MIGHT BE EASY FOR YOU TO GET TO THE DOOR LOCK FROM THE TOP OF THE MACHINE.IF YOU HAVE REMOVED THE 2 SCREWS HOLDING THE LOCK IN PLACE YOU SHOULD BE ABLE TO SEE IT HANGGING FROM THE TOP ITS BEST YOU HAVE A NEW LOCK ON HAND TO REPLACE IT.IF ALL FAILS BEST YOU SEEK THE HELP OF A TECHNICIAN.LET ME NO IF YOU NEED EXTRA ASSISTANCE.GOODLUCK.MOHAMED
May 21, 2008 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
