Question about HP Compaq Presario CQ70-120US Laptop
Spilt abt 20ml of neat vodka into lower-middle right keyboard. gentle pat off surface wet,left powered up,tilted for gravity drain.24hrs later,forced power-down,on restart could not type password,or anything else.discovered on screen keyboard.this appears 2 b only problem. please advise actions needed.thanks barbking@clear.net.nz
  • barbking Dec 10, 2009
    thank you. please explain rationale of motherboard being next.i need to understand .
    cheers,Barbara.
    yes,thank you
  • 3,940 Answers
If keyboard function doesn't return in next 24 hrs, I'd replace the keyboard
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=presario+cq70+keyboard&_sacat=See-All-Categories
if that doesn't resolve the motherboard would be next
Posted on Dec 10, 2009
  • IQUIT Dec 10, 2009
    If you replace the keyboard, and the problem still exists, then the assumption is that the keyboard controller was damaged by the spill. It being a part of the motherboard, replacing the motherboard is the next logical step if the keyboard replacement fails to resolve the problem.
How do you remove the rear seat in a 1999 Mazda 626?
heck for 2 bolts at the lower edge near the floor if no bolts push lower seat inwards and lift up it should pop up , use a large screwdriver.
Aug 23, 2014 | 1999 Mazda 626
Sticky buttons
Lifting it up may break the buttons.... Can you try using cotton bud and try cleaning it; if it can enter without forcing it; dip it in a methylated spirit and apply it gently.
Feb 03, 2014 | Lenovo Computers & Internet
Does not drain
Hello, the problem is gravity. Do the following test: disconnect the drain hose from the PVC drainage. Then bring the end of the drain hose as low as possible closer to the ground, preferably place a tilted bucket so you can catch the water instead of just spilling it on the floor. If the draining occurs, then the issue is gravity.
Solution: lift the dishwasher by placing it on a dolly or wood frame and see if the height is enough for the water to drain itself by gravity force.
Or > install a draining pump. Costly but effective.
Dec 15, 2013 | Lamber F92EK Under Counter Commercial...
We have got a samsung rv511 accidently spilt a drink in the keypad now the keypad is sticking, how do we stop it sticking?
I bet this one is pretty common! remove keyboard and gently wash or replace keyboard (reccommended) look on manufacturers site on how to remove keyboard.Do not put anything wet near you pc,,so dry (hairdryer) keyboard properly if you manage to de-semble it.
Jul 15, 2011 | Computers & Internet
How do I remove the keyboard from Asus K50IJ ?
Try these steps:
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the Asus keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus K50IJ Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus K50IJ Keyboard component toward your laptop screen. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
Jun 25, 2011 | ASUS K50IJ-C1 Notebook
Hello How do I remove the keyboard from an Asus A6J A6000 entertainment notebook? Thankyou
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus A6J Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus A6J Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
4. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right. Power on your laptop and verify that the Asus A6J Keyboard is working.
Dec 11, 2010 | ASUS A6J Notebook
Spilt wine on keyboard. Left arrow keys are not working as arrows.
hi..
this circuit board might have damaged because of wetness. try to dry up the board and clean it throught wil proper soft cloth and try using the keys.
if the problem stil presists then the circuit board is damaged so please change the keyboard
if my answer was usefull please vote me
Jul 14, 2010 | HP Multimedia Cordless Keyboard/Mouse...
How do I drain the barrel
If this is a top loading washer, an easy method of draining the wash tub is to pull the drain hose from the standpipe at the wall and lower it into a bucket. Gravity will allow the water to drain. If the washer is in a laundry room or utility room with a drain in the floor, you can simply lay the drain hose on the floor and allow it to run into the drain.
A less messy method is to use a wet/dry shop vac and pull a vacuum on the drain line to pull the water from the wash tub. Most of the these top loaders have a capacity of about 30 gallons, so you will need to empty the shop vac a few times to empty the tub. Make sure you place the drain hose back into the standpipe when you need to empty the vacuum or gravity will force the water on to your floor.
If you have any questions, please let me know. I hope you find this information helpful.
May 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Acer 2420 keyboard
You need to prise off the power button bezel and this will reveal the screws for the keyboard. Remove the keyboard screws and then gently remove the keyboard.
Oct 20, 2007 | Acer NSK8458AN Keyboard
How to open keyboard
look for a thin piece of plastic strip that runs the full width of the keyboard near its top. Pry this off gently starting with a jewelers screwdriver (careful not to score plastic). after this is out, lift the keyboard out and disconnect the electric flex circuit.
Jun 08, 2007 | Fujitsu AMILO D-8830 Notebook
HP Compaq Presario CQ70-120US Laptop Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
