Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
My washer has f2 what does this mean? - Kenmore 3.8 cu. ft. HE4t Front Load Washer
  • 6,784 Answers
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
• If the above does not correct the problem replace the pump
Posted on Dec 10, 2009
What does error code F2 mean on a Kenmore HE3T front load washer
As far as I can find out online, the F2 code indicates a problem with the drain system.
Jul 07, 2015 | Kenmore Washing Machines
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What does it mean when it gives you a f2 on error on your washer
F2 is a flooded base and that you can drain it by tilting the dishwasher back 45 degrees (have towels handy). If it continues, likely to be a leak that needs repair.
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 error
f2 means the unit is draining to slow...you need to clean your pump filter...if you need help with that post to onthejob
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
103 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
