Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Have a samsung phone with t molibe network what to use a defferinet sims card
My Samsung Galaxy S2 GT-I9000 doesn't read my SIM Card
Can't figure out exactly what the problem is. Try with the following methods.
1) The SIM card might be damaged. To check this, Try inserting the SIM card into any other active network free phone. If it doesn't work then sure the SIM card is damaged. If it works fine then the SIM card is in good condition.
2) The SIM port on your phone might be damaged. Try inserting any other active SIM card to it. If it doesn't work, then sure the SIM port is damaged. If it work fine, Then the SIM port is in good condition.
3) The phone might be network locked. If the phone doesn't allow any network SIM cards to work with it except any one specific SIM card, Then it is sure network locked. You can unlock a Samsung Galaxy S2 safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy S2 from ProUnlocking.Com at affordable cost with easy unlocking guide. Good luck.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Sim
Did you mean your Samsung S8000 Jet phone displaying invalid Sim card?You need to unlock it from current network lock,to use other network sim card.Visit the site Mobileunlocksolutions.com get unlock code and unlock it easily.Then use with any GSM network sim card.Check whether unlock code is available for your network and country.If it is available get it and unlock it.You can unlock only GSM network locked phone.You cannot unlock CDMA network locked phone.After unlock your phone you can use any GSM network sim card in it.You cannot use any CDMA network sim card in it.
Jun 17, 2013 | Samsung Jet S8000 Cell Phone
Need 8 digit network unlock code for samsung sgh-a837 Rugby
It asking for Network Unlock code...Visit the site
Onlinegsmunlock.com/samsung/rs7wp8/ get the Network Unlock code for SAMSUNG SGH A837 model phone and unlock from AT&T Network lock.Then use any GSM Network sim card in it.
Oct 04, 2012 | Samsung Rugby SGH-a837 Cell Phone
Sgh-r220 sim lock eror
You need to use other GSM Network sim card in your SAMSUNG SGH R220(R220) model phone?
It's locked to network,You need to unlock it from sim lock(network lock)Get the unlock code from the site
Simpleunlocking.com/samsung-r220/rs16wp9/ and unlock it from network lock easily..Then use other Country GSM Network Sim card.
Aug 17, 2012 | Samsung SGH R220 Cell Phone
Sim card not supported
If the Sim card Not support means it may locked to network.You need to unlock it...You can get the network unlock code from the site Onlinegsmunlock.com/samsung/rs7wp8/ for SAMSUNG GSM Network locked Phones and unlock it from Network lock.You need to specify the Model?
ALSO check whether it not support only one Sim card,if that problem means it may CDMA Network,OR may Sim card problem.If it not support other Sim card and support only one Sim means it's Under Network lock,You need to find the network,country it locked now and unlock it using the Unlock code,Only GSM Network lock Phones can be unlocked,CDMA network locked Phones cannot be Unlocked from the Mobile Phone.
Dec 06, 2011 | Samsung SGH Cell Phones
When i insert my sim the phone does not support the sim
You will most likely have to purchase a new sim card as some phones are sim card specific. Also try a jail breaking program or have it done.
Sep 26, 2011 | Samsung Cell Phones
I am With Metor, And Have a Samsung phone, but when i put my sim card into another samsung phone, I enter my passwrod for my Sim, and Network lock came up, and I need a apassword?.. This has never happened...
You need to unlock your samsung b2100 network first before you can use that sim card, To unlock samsung b2100 you must know what the original network from that phone. Example if you buy that phone from At&t vendor you will need samsung unlock code for at&t network, got it? After you have appropriate unlock code for your phone, you just need enter that code and your samsung b2100 can accept any sim card from other network. I hope my solution can help you to solve your problem.
Aug 25, 2011 | Samsung SPH-M300 Cellular Phone
My phone ask for a sim network unlock pin
That's normal if you change your original phone sim card with other sim card, you just need samsung galaxy 3 network unlock code and you can get this from your network provider or buy from third party sites. After you have samsung unlock code, insert it in your phone then your phone will be unlocked and you can change your sim card with any sim card as you like.
Jul 01, 2011 | ZAGG invisibleShield for Samsung Galaxy 3...
My sim card not working with my mobile Samsung s3600
my mobile samsung s 3600i insert sim and no network problem
Jan 28, 2011 | Samsung S3600 Cell Phone
I need a code to unlock my SGH-D415 t-mobile cellphone
HI HERE IS A SOLUTION CAREFULLY FOLLOW IT Warning: Do not enter any wrong unlock unlock codes on your Samsung SGH-D415 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-D415 mobile phone with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-D415 mobile phone is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-D415 mobile phone.
If it does not work, you can try these methods:
Method 1:
2 - ;;Phone;; will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-D415 mobile phone shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-D415 mobile phone.
3 - Compose : #0111*CODE#.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-D415 mobile phone.
Each Samsung SGH-D415 mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-D415 mobile phone at www.mobileunlocksolutions.com. HOPE YOU SUCCESSFULLY DO.... PLEASE RATE ME THANK YOU
Feb 19, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
24 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
