Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Setup.exe I am on p.7 of the manual. What is the root directory and how do I find it. Thank you Jeanne
I am at the set status screen but the system isn't doing anything. It still shows 0% after several minutes.
Janice
Posted on Apr 13, 2008
    Novelist:
  • 109 Answers
The root directory is the top directory. If you go to My computer and double click your drive. The directory you'll enter is the root.
Greetings,
DarkNeogen.
Posted on Jan 25, 2008
When i install scan cm1312 on my PC ruuning win 7 i get an Error saying Extanal Error
Are you installing the driver from the CD?
Try downloadingg the driver from their site.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3562006&swEnvOID=2100&swLang=8&mode=2&taskId=135&swItem=ma-61238-3
1. Download the file: 1312series_full_solution_v5.0_AM-EMEA.exe (306 MB)
2 Use the full download from the website and it self extracts to your root directory.To run the self extracting file, first set the compatibility mode to Vista sp2 and run as admin.
3) The files remain and you can find them here:
C:\HP_CM1312_series_full_solution_v5.0_AM-EMEA\
4) Set the compatibility mode to Vista sp2 and run as admin on the Setup.exe.
5) Run the full install. Works for both usb or network.
Regards,
Mar 18, 2011 | Computers & Internet
Tip
How to download mozilla firefox using command prompt
<ol> <li>Go to Start &gt; Run &gt; "cmd" and hit OK. This will load the command prompt. <li>type "ftp" and hit enter. <li>type "open releases.mozilla.org" and hit enter. <li>It will ask for a username, type "anonymous" and hit enter. <li>It will then ask for a password, type "anonymous" and hit enter. <li>Open the folder with the latest Windows release of Firefox by typing in:<br />"cd pub/mozilla.org/firefox/releases/latest/win32/en-US" and then enter. <li>View the contents of the current directory by typing in "ls" and then enter. <li>Switch to binary file mode by typing in "type image" and then hit enter. <li>Choose the directory to download firefox to by typing "lcd C:\" (Typing this will save it right to the root directory of the C: Drive. <li>When you typed in "ls" from step 7, it should have listed a .exe file for you. As of writing the latest version is Firefox Setup 3.0.11.exe. In this case, we will type in: <b>get "Firefox Setup 3.0.11.exe"</b> (type in the quotes) <li>Now go check in your c:/ drive, and you should see the .exe file downloaded. <li>Type "bye" to exit the FTP mode, and then type "exit" to close out of the Command Prompt. </li></ol>
on Jan 20, 2011 | Computers & Internet
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
On Sim city 3000 i can't install it when i click on the button it doesn't work and we have a dell inspiron 1150
Have you tried setup.ini or setup.exe or install.exe on the root directory of the cd-rom?
Jul 05, 2010 | Computers & Internet
I want to install arcsoft totalmedia back & record on my computer. The directions say to go to the root directory on your simmpledrive external disk drive and double click setup.exe to launch the...
The root drive is always the drive letter with nothing after it.
If your external drive is drive E, then the root is E:\.
You can see this in Windows explorer.
1. Right click on the My Computer icon on the desktop.
OR
Right click on the Computer name in the list of components to the right of the program list (Windows 7, Vista)
OR
Click Start, run, type the word explorer and click OK.
2. Look for the drive letter that says "simpledrive"
3. Click on the drive letter and look for setup.exe
I hope this helps.
Jan 04, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Wirless driver for linux
hi linksys doenot have the wireless drivers for linux but you can try the following steps:
-download the windows drivers. Extract them to c:\temp\linksys
- Now burn them or put them on a media or somthing so you can transfer these files over to linux (note: linux wont beable to extract the exe file)
- Download ndiswrapper for linux located at http://sourceforge.net/project/showfiles.php?group_id=93482
- Now make sure you have all the development tools installed in fedora
- Now download dhcpcd from http://www.phystech.com/ftp/dhcpcd-1.3.22-pl4.tar.gz
- log into your linux box as root
- Now make make sure all the files (*gz files, and linksys driver files) are in the root partition on the linux machine (/root/wireless_driver) if "wireless_driver" is not there make the directory (which u will have to do) "mkdir /root/wireless_driver"
- now at the command prompt (terminal) go into the "wireless_driver" directory "cd /root/wireless_driver"
- now type "tar xvfpz ndiswrapper-0.12.tar.gz"
- "cd ndiswrapper-0.12"
- "make install"
- "cd .."
- "tar xvfpz dhcpcd-1.3.22-pl4.tar.gz"
- "cd dhcpcd-1.3.22"
- "./configure"
- "make && make install"
- "cd .."
- "source /etc/profile" (note: you might want to edit root's .bashrc and add source /etc/profile there, some how fc3 doesnt have root source /etc/profile for some reason)
- "cd /root/wireless_driver/WMP54GS_20040423/Drivers"
- "ndiswrapper -i BCMWL5.inf"
- "ls /etc/ndiswrapper/bcmwl5" u should get a list of alot file in here
- "modprobe ndiswrapper"
- "dmesg wlan0" show see wlan0 if its there your good if not then somthings wrong - please post everything thats comes out of dmesg "dmesg > demout"
- now for a little script open your favorite text editor and copy the following code:
#Sample ndiswrapper script - By: Derrick Rose
#Load ndiswrapper module
echo "Starting Ndiswrapper Driver..."
/sbin/modprobe ndiswrapper
#Setup Essid
echo "Setting up ESSID..."
iwconfig wlan0 essid "your essid here"
#Setup WEP Key if you have one
#Uncomment below for WEP
#echo "Setting up KEY..."
#iwconfig wlan0 key yourkeyhere
#Setting up DHCP on wlan0
echo "Starting DHCP on wlan0 [ 10 sec timeout ]"
dhcpcd -t 10 wlan0
- the script above will setup your wireless card for. Now save this to a file in roots directory (/root) called wireless
- "chmod +x wireless"
- to run manually type "./wireless" as root
- If you want to automaticly load on startup do the following
- "cat wireless >> /etc/rc.d/rc.local"
restart the computer..adn then check
vedhick.....
Jan 08, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
To remove setup.exe file on digital voice recorder rca rp5120
It takes up very little space (about 3 meg), I would recommend keeping the file on the device so you will have it when you need it.
You cannot play the .VOC files unless you use the proprietary software to either play the .VOC files or convert them to .WAV or .EXE.
But if you insist, you may use windows explorer and browse to the filesystem on the Digital Voice Recorder and delete the file named "Setup.exe" you will find in the directory called "SETUP". To do this, you may have to rightclick on Setup.exe, then click on properties and uncheck the "read-only" attribute. Now you should be able to delete the file. Repeat the process for the directory called "SETUP". If you try to do the directory first, you will be given the option to change the attributes of the directory and all files contained in it. That should work too.
WARNING:
At the very least, copy the contents (a single file called "setup.exe") to a safe place.
Jul 04, 2008 | Computers & Internet
SimpleTech 250GB USB, 3.5" external hard drive. They say in manual "USING ARCSOFT® TOTALMEDIA BACKUP & RECORD. Go to the root directory on your SimpleDrive external disk drive, and...
With the usb drive connected to the pc,
Open my computer, there will be a new drive listed there (ie: f: ) or something like that.. This is your usb driver.. double click on that, and in there, there should be a setup.exe file, double click that to install Arcsoft.
Mar 29, 2008 | Computers & Internet
Funny UST scandal virus
Funny UST scandal virus Disinfection.. Virus Disinfection Using McAfee Antivirus
1. To disinfect the virus please download the latest sdat????.exe from this site and save it C:\TEMP
2. Now restart the System and press F8 key
3. Select Safe mode with Command Prompt
4. Then change directory to C:\TEMP
5. There type the filename and give the parameters as follows:
C:\TEMP>sdat5185.exe /e
After few seconds in that directory you will find some files that extracted from the dat file.
6. Give commands as follows:
C:\Temp>SCAN /all /adl /clean /report Report.log
This will clean all the virus in the system.
Hope this will helps you..
If this works please comment me.....
Nandu :)
Dec 30, 2007 | Computers & Internet
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
319 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
