Question about Dell Latitude C510 Notebook
Hello hive file systemroot\system32\config\software
  • rxanto Jan 20, 2008
    hi i dont hear any audio on my laptop dell latitufr c610
    cam u help mein getting the audio driver
    Genius:
  • 1,601 Answers
  • 49 Answers
Sir this has a simple solution... you have either installed a wrong driver installed or you never installed it at all... take out that laptop cd that come out with your unit when you bought it and install he sound driver...
rank me if this help ok...
Posted on Jan 20, 2008
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
On boot get a blue screen that reads; The registry cannot load the hive (file): \Systemroot\system32\Config\SOFTWARE or its log or alternate. It si corrupt, absent, or not writable. Cant enter bios it asks...
there is aback door password either you or some one have created and forgot.
You can try from this website,along the help of your nearest technician.
click here
Hope it will help you.
Dec 31, 2010 | Acer Aspire 3610 Notebook
My laptop will not boot, instead it goes to a blue screen that states it is not able to access the hive.
I think this is the exact error : Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION:
To resolve this issue, please follow one of the following methods.
Use the Recovery Console Tool:
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console. You need your original XP CD, boot your PC from the CD and press R when it say 'Press 'R' to use recovery console.
In Recovery Console, change to the c:\Windows folder.
Type cd system32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
i understand this looks a litle daunting, please get back to me if you have any trouble with this.
Oct 16, 2010 | Sony Computers & Internet
How Do I Repair A Stop c0000218 {Registry File Failure} The Registry Cannot Load Hive (File): \SystemRoot\System32\Config\Software Error
The registry is corrupted. To fix it all you have to do is to reload the last backup or the last known good configuration.
If you don't have a backup or it has also failed, then you must reinstall.
Sep 27, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
C0000218 Registry file failure. Registry cannot
The hive file is the problem, it is low on honey. Put it back to where the bees can produce enough honey for your PC to recognize it. Compaq's are notorious for their love of honey, that is why it is showing it is missing. DO NOT simply put honey on a CD and insert. Will not work.
Feb 01, 2010 | Compaq Presario 5000 PC Desktop
Packard bell versa e400
Hi
files in system32\config\ are missing or corrupt.
there is a back up stored by default at c:\windows\repair
you can copy the contents of windows\repair folder into system32\config\ and it should solve the problem, you can do it with the windows installation cd by using the recovery console.
Go into the repair folder enter the following commands in repair console
cd windows (press enter)
cd repair (press enter)
copy *.* c:\windows\system32\config\ (press enter)
files should be copied
type exit, quit or restart or reboot to restart the computer.
May 22, 2009 | Dell Inspiron B120 Notebook
Looks like registry problem
use registry cleaning softwares or repair your operating system
Apr 18, 2009 | HP Compaq Presario V2000 Notebook
WINNR\SYSTEM32\CONFIG\SYSTEM error
do it
1.
Use the Windows 2000 CD-ROM or the Windows 2000 Startup disk to start the computer. 2. When you see the "Welcome to Setup" message, press R for "repair." 3. Press C to run the Recovery Console tool. 4. Select the installation that you want to repair. 5. Type the administrator password.
If the computer is a domain controller, type the password for Directory Services Restore Mode when you are prompted to do so.For additional information about the Recovery Console tool, click the article numbers below to view the articles in the Microsoft Knowledge Base: 239803 (http://support.microsoft.com/kb/239803/EN-US/) How to Change the Recovery Console Administrator Password on a Domain Controller 223301 (http://support.microsoft.com/kb/223301/EN-US/) Protection of the Administrator Account in the Offline SAM 6. At the Recovery Console command prompt, type the following commands, pressing ENTER after you type each command: cd system32\config
ren system system.old
ren system.alt systemalt.old
7. If you have run the Emergency Repair Disk Wizard from Windows Backup and Recovery tools, copy the backup of the System hive from the %SystemRoot%\Repair\Regback folder.
If you have not run the Emergency Repair Disk Wizard, copy the default System hive from the %SystemRoot%\Repair folder.
IMPORTANT: You need to restore the most recent copy of the System hive. You also need to reinstall any hardware device drivers or programs that run as services that you installed since the last time that you updated your Emergency Repair Disk.
To copy the default System hive, type the following command, and then press ENTER: copy c:\winnt\repair\system c:\winnt\system32\config To copy the System hive that was backed up the last time that you ran the Emergency Repair Disk Wizard, type the following command, and then press ENTER: copy c:\winnt\repair\regback\system c:\winnt\system32\config 8. At the command prompt, type exit, and then press ENTER to restart your computer.
Jun 23, 2008 | Compaq Presario 1200 Notebook
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
CAUSE
RESOLUTION
To resolve this issue, use one of the following methods.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
Type cd sytem32\config , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Oct 23, 2007 | Computers & Internet
Dell Latitude C510 Notebook Logo
170 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
