Question about Kenmore Washing Machines
We have a Kenmore 80 series washing machine. It seems to be locked up. I can't even turn the agitator with my hand and it should move freely in one direction. All it does it hum when on. It filled up but won't do anything else.
  • 2 more comments
  • gonecadd Dec 12, 2009
    Model # 110 82881800
    I noticed last night when the lid is closed or the switch is pushed down that's when it hums.
    Hubby talked to a repair guy who thinks it's the switch but I'm not so sure since the agitator won't even turn.
  • gonecadd Dec 13, 2009
    I tend to think it's the coupler too.
    We replaced it a few years ago but I can't remember what it's symptoms were at that time.
    I've tried it on every setting and it will only hum.
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem.
    President:
  • 1,937 Answers
First, see the Sears Parts Site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82881800+
See the diagram and parts list for the gearcase and motor.
The first thing that I'd check is to try the washer on a different cycle.
If you have the same humming, the problem points to the "Motor Coupler"
If you have a two piece agitator, the top section is designed to turn in one direction only. The lower section is directly connected to the transmission and motor and would be rather difficult to turn by hand.
If the top section doesn't turn either way by hand, the problem is likely stuck or damaged "agitator dogs"
See the following for how to check and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=a2797be1c361c35ce136411c4953110d
If they are damaged, they are rather inexpensive and easy to replace.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Dec 13, 2009
Lumpy816
  • 246 Answers
SOURCE: Kenmore 80 series won't spin
Some models will agitiate for a couple of minutes even with the lid open. Try listening when you close the lid for a "click". If it is missing you may have a bad lid switch.
Posted on Jun 13, 2008
marka19
  • 1430 Answers
SOURCE: 80-series w/ broken top agitator
There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Posted on Mar 28, 2010
  • 65 Answers
SOURCE: My Kenmore 80 series fills with water but nothing
Mine did the same thing. It was bad lid switch. It is best to replace switch, but you can bypass it by cutting its two wires, connecting them together, and taping the spice. Be aware by doing so that the washer will now agitate and spin with the lid up, which is the purpose of that switch. Also unplug cord from wall before doing any repairs. Attemp only if you are comfortable with wiring repairs.
Posted on May 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 80 series, fills up andn agitates but will not spin or d
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Daniel S
  • 4323 Answers
SOURCE: Kenmore series 80 will fill
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 05, 2011
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
My Sear Kenmore washing macbine will barely agitate when using the full size load. It barely moves, but on small or medium loads it works fine. What seems to be my problem?\r\nModel #110.26292692 SN#...
Take and turn the agitator by hand. It should only turn one way. If the agitator will turn freely either way, then you will need to replace the "agitator dogs" that go in the top of the agitator. Take a look at this video.
Jul 21, 2011 | Kenmore 16812 Washer
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Mar 28, 2010 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore 80 Series washing machine agitator is not moving much
sounds like you motor coupling may have broken, part is about $20
Jan 17, 2010 | Washing Machines
Kenmore series 80 washer: does not twist in the middle
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced.
Remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Part number is 80040
Let me know if you need more help.
Apr 01, 2009 | Kenmore Washing Machines
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
drum is stationary in wash and moves only in spin
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
258 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
