Question about HP Officejet 7210 All-In-One InkJet Printer
HP Officejet 7210 All-in-one
I have a carriage jam on HP Officejet 7210 All-in-one. How can I clear it?
  • Anne Morrissey Nov 07, 2008
    my officejet 7210 will make the most obnoxious noise and then the display say carriage jam. the noise will scare you half to death it is so loud.
  • 16 Answers
  • 8 Answers
SOURCE: hp officejet 7210 allin one,carriage
I had a "carriage jam" error message.
My son gently wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, took the drive belt off/put it back on (not easy), and found nothing wrong with it. So, I put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
I had the same problem with my DVD player. The head was hanging up on the two chrome plated rods that supported the head. I put some 3-in-one oil on the rods, ran the head back and forth, and it has worked ever since.
You might also check the belt to make sure that there is nothing that might cause it to hang-up.
Kevin
Posted on Jan 31, 2009
rockfixya
  • 679 Answers
SOURCE: HP Officejet 7410 "carriage jam"
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
  • 71 Answers
SOURCE: Carriage jam
Step 1: Move the carriage to the center manually if necessary If the carriage is stuck on the right or left side of the product, follow these steps to move the carriage to the center of the product.
Step 2: Check for a broken carriage chute
The carriage chute is the side wall of the carriage that holds a curved metal piece (the x-bias spring). A broken carriage chute might cause the carriage jam condition.
Step 3: Turn the product off and on again
Step 4: Clear any paper jam.
Step 5: Make sure that the control panel faceplate is correctly installed
Step 6: Plug the All-in-One directly into a wall outlet
Step 7: Perform a partial reset
Step 8: Print a self-test page
Step 9: Service the product. Now this model is outdated as per HP website.
Posted on Aug 23, 2009
SOURCE: HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Posted on Jul 17, 2010
  • 1705 Answers
SOURCE: how do you clear a carriage jam from an HP
Here's a couple of useful links :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01389539&cc=us&lc=en&dlc=en&product=2512010
and
http://www.youtube.com/watch?v=_xLYHteCIBc
Posted on Jul 21, 2010
I keep getting a carriage jam error message. There doesn't appear to be a jam, but I am unable to clear the message and print anything. Also the display screen reads original loaded. No idea what this...
Check the location of the ink carriage. If a piece of paper gets wadded up under this or something else is obstucting it you will see this error.
The original loaded message comes up when a sheet of paper is in the scanner tray.
Apr 01, 2011 | HP Officejet 7210 All-In-One InkJet...
The printing carriage stalled and I get error message : Clear carriage jam ..
This normally happens if there is something jammingthe head assembly from moving along the carriage rail. Turn off the power to the printer and see if you can move the head assembly by hand. Also check that there are no paper jams anywhere in the paper path and that the belt that moves the head assembly has not broken.
Nov 10, 2009 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
Aug 23, 2009 | HP Officejet 7210 All-In-One InkJet...
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
Hp officejet 7210 allin one,carriage jam,tried all hp troubleshooting
Kevin
Nov 24, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
It's telling you that something is in the path of the paper or a paper is stuck in the machine. There is a panel on the back that removes quite easily. Check there. Also, check where you put in the ink, there may be a paper in there. Also look for bits of paper. Sometimes in a jam, the paper gets ripped and a piece of it is still there.
Jun 19, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
Try this (it may not work) -
Perform a Semi-full Reset on the unit by following the steps below:
1. Make sure that the unit is on, and disconnect the power cord from the back of the unit.
2. On the unit keypad press the # and the 6 keys simultaneously and hold both keys down while plugging in the power cord.
3. The Semi-full Reset message will appear on the unit display.
Wait until the unit initialization process is complete. The unit will have recovered its original settings.
I've had this error before and had no obvious fault with the carriage (it moved freely and the encoder strip was in place) i managed to clear the error by stripping the printer down and cleaning around the service station area
May 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
350 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
