Question about Casio Exilim EXZ1050 Digital Camera
The EX-Z1050 will not turn off. ONly the red light keeps blinking. The lens is out and nothing happens when pressing any buttons.
  • 1 more comment
  • Ronxxx Dec 10, 2009
    Thanks but we did remove the battery and reinsert it. The camera just does nothing but the red light blinks.
  • Ronxxx Dec 11, 2009
    As I told you last time you suggested this, we have done that. Taking out the battery for any lenth of time and putting it back in does not change the condition. It is still hung up. The lens does not retract and none of the buttons work.
    Thanks for your help. This didn't seem to do anything either.
  • 10,515 Answers
I have seen this Problem on Most of the Models in Canon As well. Do you See any Lens Error ?
It Sounds as the problem is with the gear-motor alignment of the lens which moves in and out with the help of motor. This part is usually Replaceable. I would guesstimate the cost of repair around $100. You can disassemble the camera yourself and the check the plastic and fiber gearing and teeth for the lens. They are minute parts which get misaligned due to physical shock or manufacturing defect.
Let me provide you with all the Steps you need to Try ( Though i know, you might have Tried most of them )
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
5. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
6. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
    President:
  • 2,185 Answers
Hi there Ron,
With new batteries inserted in your camera, try to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Posted on Dec 11, 2009
  • 3,741 Answers
The unit is hanged. just hard reset it
Remove the battery for a minute a reinsert it again.and turn it ON.
this will reset the unit and it will start working properly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Dec 10, 2009
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Hello! casio ex-z1050 no longer included. The unit does not drop. Just put it on a shelf in the set state with the lens. It took no more than 1-2 minutes corrected the subject and returned him. When...
I'm afraid I find it difficult to understand your query - however, this camera is now ten years old, and all consumer electronics have a limited life. The cost of repair would far outweigh the cost of a replacement.
Apr 03, 2017 | Casio EX-Z1050 Digital Camera
Wii Controllers not causing anything to happen.
OK so do led lights on the on the bottom of the controller just keep blinking or ever light up under "1" to signify that it is connected? What you do if they keep blinking is take off the battery cover on the remote and press the red button and the red button under the sd card cover at the same time. This syncs the wii remote with the console. You will need to do this with all new wii remotes.
Jan 11, 2010 | Nintendo Wii Console
Frozen, locked up with blinking green light.
If you cannot get to "reset" in the camera menu, then here is how to do a manual reset...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 07, 2009 | Cameras
When I switch of my Exilim EX-Z1050 nothing happened. It seem that the lens are blocked. What can I do?
I decided to give the camera away.
Thank your for your kind offer
Kind regards
FJ
Aug 07, 2009 | Casio Cameras
My Casio Exilim EX-Z60 6.0 mega pixel camera stopped and froze
All you can do is reset the electronics to factory defaults. Or contact mfg for protocol to accomplish this.
Sep 21, 2017 | Casio Exilim EX-Z60 6MP Digital Camera...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Multiple Problems
The zoom and power button are all part of one small assembly/circuit on the EX-Z1050. It sounds like this piece is faulty.
Jan 28, 2008 | Casio Exilim EX-S500 Digital Camera
Sharp Projector
to reset lamp timer, hold down enter, arrow down, and arrow right, then press the power button.
Feb 20, 2007 | Sharp ANW9Z WIDE ANGLE COVERSION LENS...
Casio Exilim EXZ1050 Digital Camera Logo
114 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
