Question about Jabra BT250 Consumer Headset
Connecting cell phone and Jabra
My cell phone doesn´t find any BT device when I try to pair my Jabra BCE250. I´ve tried other cell phones and found the same problem.
  • 47 Answers
Check that both devices are BT enabled and in pairing mode -ie, leds blinking-. If one of the device is not in pairing mode, it is normal that the process fails.
If you experience the same problem on other phones with your Jabra BCE-250 -same as mine-, you might think of getting it checked first.
Posted on Jan 07, 2010
Jabra Cruiser2 Type HFS002. Need help with connecting Jabra to cell phone via bluetooth.
If you have the instruction manual on the jabra, it should tell you how to put the device in pairing mode. Once pairing is turned on you find the device name through the bluetooth settings on your phone. Click pair and they should connect.
Aug 16, 2016 | Cell Phones
I'm having difficulties pairing my iPhone 5 with my Jabra Cruiser. The unit appears to be in pairing mode when it turns on (flashing), but I never receive verbal confirmation from the unit. I'
the Jabra Cruiser is most likely not compatible with your iphone 5. Apple makes their products to connect only with their products most of the time. ive tried connecting my tracfone\'s bluetooth to my ipod touches bluetooth and cant pair them. Xbox 360 pulls the same issue too. so you probably will have to purchase a different car cruiser
Apr 18, 2013 | Jabra Cruiser InCar Speakerphone Black
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
Someone change my passkey of jabra bt2070 how i get it
hello first i would like to know if your phone is paired with ur bt device if it is and it is asking for your pin code again most pin codes for manufactures are as follows 0000,9999,1111,or 1234.hope this is the answer you are looking for..now if your device is not connected you need to reconnect the device to your phone ,follow your cell manufactures procedures for connecting your bt device and make sure u set your bt device to discovery mode,then when it asks for the pin code enter one from above most are 0000 but the odd time one of the other codes is required...hope this helps
Feb 22, 2011 | Jabra Bluetooth Headset - BT2070
I have my first cell phone pair with my Jabra BT2035 headset, how do I pair my second cell phone with this headset?
While you can't actively be connected to 2 phones at one time, you can pair with more than one phone. Just turn off the headset, then hold the call/end button on the headset until the status light stays solid. Initiate search on the 2nd cell or PC/Mac and if prompted enter the 0000 pair key.
Now you can connect to the Jabra from one or the other phone/computer. I used this method for to connect to my blackberry for work and n97 personal phones.
Jan 06, 2011 | Cell Phones
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
RAZR V3 WITH PLANATRONICS BLUETOOTH
try a master reset of the phone or delete all BT devices in your list....hopefully this corrects the issue
May 26, 2008 | Motorola Mobility RAZR V3
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Jabra BT250 Consumer Headset Logo
491 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
romy sibug
romy sibug
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
