Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
Sim card doesnt work on my i68
Yes, it didnt have a problem in the begging but now it doesnt read it both slots say to insert, i dont know wat 2 do
Sim card problem
if it cant read your sim card it must be something with your hardware. either get your simcard replaced or itll be the simcard slot in your phone.
check the slot with a different sim card and if it works then its your sim card that doesnt work.
if they both dont work try them both on a different phone and if they work there get your phone checked.
Dec 06, 2013 | AT&T Radio Communications
I68 sciphone is not picking up an att at&t signal
I have my boyfriends ATT sim card in the phone plus my T-mobile. Both work fine. Go under settings and Dual Sim Settings and make sure whatever slot you have the card in is turned on. If you have more than one sim card in it should be on Dual SIM Open. If not pick which slot it's in and turn it on :P If that's not it then sorry I dont know. Just a thought.
Aug 24, 2009 | Cell Phones
I68, not read sim
Change of the SIM Places that you inserted !
Insert your working SIM1 to phone SIM2 SLOT Insert your not working SIM2 to phone SIM1 SLOT
Solution :
  • If your SIM2 that you inserted into SIM1 SLOT remain not working !
  1. Your sim card is defected or Phone does not support this sim card!
  • If your SIM1 that you inserted into SIM2 SLOT is not working
  1. There is a problem with phone's SIM2 SLOT
In case of SIM2 SLOT problem i can help you to get it fixed contact : omniarepair at gmail dot com
Best Regards
Jun 24, 2009 | Dual Cell Phones
My sciphone i68 + doesn't read my sim card
flip the sim card over and cutoff the other sim slot example"if chip is face down make it face up" if that doesnt work switch to other sim slot and repeat the steps above if that doesnt work you can go to this link for more help
http://www.freewebs.com/sciphone/index.htm
Jun 10, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Sim card problem
make sure the sim card is inserted properly. sim card slot 2 is the one away from where battery cover (against the phone) the gold chip will face up towards you. sim card slot 1 is the one slightly elevated gold chip will face down. if you are sure you have it inserted correctly, follow the steps below that came off the help disc i have offered. Works for I9 and I68.
Emergency calls only, then try these steps;
1.) Shut down the phone, remove the SIMS, and replace them back in the slots in the
correct manner again. It may just be that the SIMS aren't in correctly, not pushed far enough
into the slot, or their metal grid isn't making good contact with the SIM's slot pins. Try to
wedge a tiny piece of paper, placed against the side of the SIM without the metal contacts, between the phone and the SIM so it makes the SIM's metal contact points fit up against the phone's SIM slot contacts a little more snugly.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 04, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Invalid sim message on i68 phone
i have the same problem i keep on putting my sims in (one tesco sim & one voda phone sim) and it said the same thing invalid sim. the sim regestars for about 2 seconds then it either says invalid sim or emergancey calls. whats a matter with it should i send it back.kjr2502
Mar 12, 2009 | Dual Electronics CECT P168 Cellular Phone
I just bought a sciphone i68 & my sim card from my old phone won't work in it. Do I have to get another sim card?
Slide the sim card back and forth slowly in the correct slot oriented correctly make sure you're in the correct slot, there are two. Mine did the same thing and it fixed it.
Oct 21, 2008 | Cell Phones
Tmobile dash won't read my sim card
Have you inserted the Sim correctly. The Sim goes in with the gold plated contact facing down and the cut corner of the sim on the bottom right corner showing when inserted.
Feb 26, 2008 | T-Mobile Dash Smartphone
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
89 people viewed this question
Top AT&T Cell Phones Experts
Oloyede Monsuru
ismael castillo
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
