Plugged in mouse to USB port. Installed using disc. Laser not lighting up on mouse and therefore no actio. This is the second one I have tried the previous one's middle button stopped working after a coupe of weeks of use. The shop exchanged as I had my receipt however this time I have mislaid my receipt and would like some help to sort out the problem as I am unable to exchange without the receipt. Would be gratefull for advice asnot at all usable!! Thank you Lesley
  • 1,271 Answers
Hi Lesley, I take it you have tried another usb port ? and that mouse on another PC.
you might need to download the USB hub driver for your board if windows generic driver is causing problems.
Can I suggust you goto the control panel select the Device Manager and select the USB Hub(s) and press the delete key.
Now reboot the machine and it should reinstall the generic drivers for USB , try it now, look for updated drivers regarding the USB. if that still does not provide you with a solution then I suggest buying a USB pci card. But Please make sure the USB devices work okay first.
Regards
GeWiz.
Posted on Dec 10, 2009
How do I connect my Logitech wireless mouse to my computer
I use Logitech wireless mice and so does my wife. After a battery change you have to reconnect the mouse with the wireless receiver
. First push the button on the receiver, then push the button on the bottom of the mouse. It should connect and you will be ready to go. If this doesn't get the mouse working, you may have to unplug the mouse, then plug it back in the USB port, then reconnect to the receiver. Hope that helps.
Sep 30, 2014 | Logitech Cordless Mouse
Doesn't work.....no laser light appears on the bottom of the mouse. Nothing happens when I hit the "connect" button.
It sounds like these is either a problem with the USB port on the motherboard or with the mouse itself.
Assuming that if a wireless mouse: the batteries are new, the device is actually turned on and the transmitter has been removed from the mouse and plugged into the the USB port and it still does not work, it should be tried on all the other USB ports of the computer. If none work, try on another computer.
This will help determine if the mouse or the computer is the problem. If the mouse does not work on other ports or on the other computer, a defective mouse is likely. If it does work in a different USB port of the original computer, the first USB port is suspect.
If it only works on a different computer, the problem my lie in the setup or BIOS page of the computer. Look for a setting for USB ports. Enable the ports if disabled, and try again. If still no luck, there is some other issue at the motherboard level. Unless fairly new and under warranty, it will probably not be worth trying to fix the problem, when a $20 USB expansion card could be purchased and installed to provide USB connectivity needed.
You could also try connecting a different USB device (if available) to test the USB port. A USB webcam, hard drive, mechanical mouse, etc. are all good choices to test the port. You should indicate or cover any ports that are found to be defective.
I hope this helped and good luck!
Nov 01, 2010 | Computers & Internet
Laser doesnt work
Check the mouse cord and make sure that it is properly connected to the PS2 port of you computer. Turn off your computer, wait for a few seconds and then power it on. If it failed to function properly, contact the store where you bought it about the problem. The device is cover by its' warranty and they may replace it if found defected.
Hope this could help you..:-) Thanks..
Dec 27, 2009 | Genius Mouse, OEM Net Scroll PS2...
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
Jul 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
New pd7260lsr not working
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 08, 2009 | Micro Innovations PD7250LSR Wireless RF...
Keyboard want light up but mouse works
The buttons on the top (silver) are linked to your "Favorites" folder in Internet Explorer.
The buttons to the right of that are used for your media player (To skip tracks and adjust volumes, play pause etc)
The buttons on the left (from top to bottom) are:
1) My documents folder will open
2) MSN or Windows Live! Messenger will open
3) Your E-Mail will open (whatever your default email program is)
4) Calculator Opens
5) Windows Update will open
Now... In order for these you HAVE to have the drivers installed. If you didn't get a CD with your keyboard, you can download the drivers directly from Microsoft here:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Just fill in the drop-downs and press "Go", it should show you a link the the exact driver you need to install. Once it's been installed you can set up your favorites with the software that it installs.
Oct 24, 2008 | Microsoft Wireless Optical Desktop Comfort...
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Mar 02, 2008 | Sakar 62150 Keyboard
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
