Question about Maclaren Burberry Umbrella Stroller
I need new latches and wheels for the burberry stroller can you help
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
You should be able to get it from www.buggypitstop.co.uk
Posted on Dec 11, 2009
SOURCE:
Instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
How can I fold?
Kindly follow the steps below on how to fold the stroller:
Apr 16, 2016 | Baby Gear
How do I let the stroller down?
    Kindly follow the steps below to fold the stroller:
Sep 09, 2014 | Evenflo Aura Traditions Travel System...
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
How do I transform the stroller from upright to laying down? I want to lay it down to put it in the back of my car...
what type of stroller is it..if its the small cheap kind called umbrella stroller then its usually a latch on the bottom near the back wheels...and if its a larger one it could be near the top handle.....i have 3 strollers and the bigger ones both close from a latch at the top look for something red a button or latch
May 08, 2011 | Toys
Where can I find a manual?
hi
most maclaren buggy are the same here is a manual for the quest which i believe is the base model
for the burberry styled please click on the download to view
http://global.maclarenbaby.com/toddler-buggies/quest-sport?lang=en
Oct 22, 2010 | Maclaren Burberry Umbrella Stroller
Burberry stroller coverall fitted
Item no longer available since early 2010. Sometimes available pre-owned on eBay for aroun $400 - $600.
Oct 09, 2009 | Maclaren Burberry Umbrella Stroller
Brake malfunction, not gripping tires
Bugaboo sent out new brake feet which are the green things even put of warrenty have you tried bending them back into shape sometimes they get knocked /damaged just out and about!
Aug 12, 2009 | Bugaboo Cameleon Jogger
Need replacement fabric and hood
I know that Maclaren USA gets their parts from Maclaren UK on these strollers, so you may have to go through them directly. Try emailing them at info@maclaren.co.uk
Or if you have free long distance, call England 9am to 5pm Mon-Fri: 01327 841310
(FYI - They are 8hrs ahead of us)
=) Good Luck! from Moms Just Know
Nov 01, 2008 | Maclaren Burberry Umbrella Stroller
How do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Jan 24, 2008 | Zooper CoolZone Sport Stroller
Maclaren Burberry Umbrella Stroller Logo
98 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
vanyell
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
