Question about Tag Heuer cj1110.ba0576 Wristwatch
How to pull out the crown of tag heuer watch and adjust the time and date
escapement
  • 2334 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
rootbeer001
  • 352 Answers
SOURCE: Tag Heuer watch
The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
Good luck.
Posted on Mar 25, 2010
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
Posted on Mar 15, 2008
escapement
  • 2334 Answers
SOURCE: how to set the time on a tag heuer
  • 2501 Answers
SOURCE: Tag Heuer date adjustment doesn't work.
The date change occurs at midnight, so winding it past midnight changes the date. To change it again wind the hands backward to (say) 11 O'clock) and then forward again will change the date again.
How far you need to turn it back will have to be found by experiment.
Posted on Jan 03, 2010
Instruction manual
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps .
Sep 01, 2013 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
I can unscrew the crown completely out of the tag watch but how can i set date and time
The "Normal" is unscrew the crown, then gently pull the crown out very gently until you feel the first "CLick". THis is your date adjustment. Pull gently again, and you will feel another click, this is your time adjustment.
Sep 25, 2010 | Tag Heuer Formula One
Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
Some watches need to have the crown unscrewed.
Try turning it anticlockwise then pull out.
If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Tag Heuer date adjustment doesn't work. I pull the crown out one notch, turn it clockwise, and nothing happens. Turn in it counter clockwise, nothing happens. ???? The only way to adjust it is by adjusting...
Jan 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
How can i make the date of my tag heuer formula 1 change automaticaly?
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Oct 10, 2009 | Tag Heuer Formula One
How do i change teh date on my tag watch with out having to wind it 24 hours to change one day. i need to change 15 days
If you pull out crown carefuly, you will notice there are two clicks. The first one is for adjusting calendar (day or/and date). Next one is for moving hands. Pull out to the first click and adjust the date by turning the crown.
Rate me, please.
Aug 04, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer watch runs fine; can't set time or date. What am I doing wrong?
Are you aware that the crown is threaded and it needs to be unscrewed and pulled out once to adjust time and twice to adjust date
Jul 25, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
Quickly change date on my Tag Carrera
When yoy pull out the crown you will notice there are two clicks. You have to pull out crown to the first click only and then adjust a date by turning the crown.
Rate me, please.
Mar 13, 2009 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
How to adjust the date in tagheuer watch
Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
Dec 05, 2007 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Tag Heuer cj1110.ba0576 Wristwatch Logo
2,226 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
