Question about Brother IntelliFAX 4100 Laser Fax
I have a 2-3 black line down the page. I cleaned
I have a 2-3 black line down the page. I cleaned it and it won't go away. Any advise
  • 1,297 Answers
Change the chrage roller and the OPC drum and cleaning blade.
Posted on Dec 12, 2009
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Black line down the center down the page
If it is a lazer printer a score on the photosensitive drum will leave a black line. Sometimes it is less grevious cace of an accumulation of ink leaving a line around the drum. This can happen when printing many dark background or full bleed copies. These drums are seensitive but can be carefully cleaned. Work away from direct strong light.
Regards
Apeal
Aug 20, 2009 | Canon Office Equipment & Supplies
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Feb 02, 2009 | Brother MFC-7820N Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Black stripe down one side of every fax
On my Brother fax machine, there is a blue plastic cleaning thingy on the toner cartridge used to clean the metalic wire. If you leave it on the wrong side after cleaning, you get a thin black strip down the edge of every page. Slide it over to the other side and problem goes away.
Jul 08, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Black lines through documents
Try cleaning the cartridges to see if that helps..... mine did the same thing and after I cleaned it, it worked like new.
Feb 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
Brother IntelliFAX 4100 Laser Fax Logo
417 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
