We just bought the Bemis ED11 800 and there doesn't seem to be any moisture blowing out. We let it run all night and the humidity level in the room did not change at all.
I realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Check Filter Indicator
The ability of any humidifier to efficiently supply humidity output relies heavily on the
condition of the filter. As the filter loads with impurities it gradually loses its wicking
capability. When this happens, moisture output is reduced and the humidifier has to work
longer to satisfy the selected setting. This humidifier has a check filter reminder timed to
appear after 720 hours of operation. When the Check Filter (CF) message is displayed,
disconnect the power cord and check the condition of the filter. If a build-up of deposits or
severe discoloration is evident replace the filter to restore maximum efficiency. The CF
message is reset when the humidifier is plugged back in.
