Question about Pantech Matrix Cell Phone
Default Bluetooth PIN??
When I try to connect my pantech c740 cell phone with my sons c740 via bluetooth I get a request for a PIN code. I did not set up a PIN code. Is there a default for these models?
Pantech c740 country lock solution
Hello:"::"
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 21, 2013 | Pantech C740 Cell Phone
Install applications c740
how can i dawnload jar bluetooth , and setings to connect wireless, and nafigation connect to network
Jul 29, 2012 | Pantech C470 Matrix Smartphone
I can't download the pictures off my pantech cell phone
You can connect your Pantech Link to your Windows 7 computer using the phone's built-in Bluetooth adapter. If your computer doesn't have a Bluetooth adapter bulit-in, you can connect the phone via a USB port. Once you connect your Link to your computer, you can use the phone as a modem, or transfer files back and forth between the phone and the computer.
Press the "Menu" key on the Pantech Link and select "Settings."
Open "Connectivity" and choose "Bluetooth," then "Activation." Set the option to "On" and press "Select."
Click "Back" and open "Visibility." Click "Show" and press "Select."
Click "Start" on the PC task bar, then click "Devices and Printers."
Right-click on your Bluetooth adapter and left-click "Bluetooth Settings." Check the box labeled "Allow Bluetooth Devices to Find This Computer" and click the "OK" button.
Click "Add a device" at the top of the screen. A new window pop ups, showing the nearby Bluetooth devices.
Highlight the Pantech Link and click "Next." A random number appears on the next screen.
Wait for the Pantech Link to prompt you for the number, then type the number into the phone and press "Select" to finish the pairing process.
Right-click on the Bluetooth adapter on the computer and left-click "Bluetooth Settings." Uncheck the "Allow Bluetooth Devices to Find This Computer" box and press the "OK" button. This prevents the computer from showing on other Bluetooth devices.
Regards.
Jun 18, 2011 | Cell Phones
How i connect my note book to my htc bia bluetooth
Hi,this is a detailed step on how to connect your htc to your notebook via bluetooth. STEP 1. Turn on the bluetooth of your htc which is accesed at the connnectivity settings of your phone.
STEP 2 Ensure you also put on the bluetooth on your notebook,most notebooks have a single button in front of the keyboard,to turn on the bluetooth. STEP 3 You now go to the bluetooth settings on your phone,and click on 'add device'.when you click on it,it requests for a pass code,when this is done for the first time,this pass code can be any 4 digits of your choice. STEP4 After entering the pass code on the phone,a pop up shows on your notebook requesting for the same pass code you entered on your phone. Ensure you enter the same pass code for both the phone and notebook,if not the devices won't pair via bluetooth.
STEP 5. After entering the pass code on the notebook,the notebook is automatically paired with the phone via bluetooth,afterwards you can be able to transfer files between the phone and the notebook via bluetooth.
Thanks and take care
Apr 21, 2010 | HTC P3450 Touch Black Unlocked...
Att pantech phone c740 will not pair with the 2010 prius bluetooth system
You have to check with the Toyota Service dept and bluetooth support. They have a list of the devices their bluetooth technology supports. Not all bluetooth devices are supported by any one bluetooth service. They should have a list of their supported devices.
Oct 31, 2009 | Lands Phones
Pantech matrix reset and unlock codes
Pantech C740 Matrix Cell Phone default passwords for master reset and master clear are both '1234'.
I hope that helps.
________________________________________
Download Pantech C740 Matrix Manual Here.
Oct 15, 2009 | Pantech Matrix Cell Phone
I need the pairing code for LG KS360
The default pin code for most devices, especially headsets, is 0000 unless it was changed.
You should be able to go into the bluetooth settings on each phone, and find the security code there, or at least change it.
Sep 15, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
I have bought samsung w299
I can't solve your memory card problem.
I can however solve your bluetooth problem. Your phone is looking for the default pin code of whatever device you are trying to connect. Usually these pin codes are the following:
1234
0000
1111
If you can tell me the device you are trying to connect I will be able to tell you the default pin code.
Sep 01, 2009 | Samsung Omnia Cell Phone
How do you connect h700 motorola bluetooth to pantech matrix
give the bluetooth an initial charge, turn it on, go to the bluetooth settings on the matrix (refer to the owners manual), its in the menu somewhere, all phones are different. When you get there go to "add device", it will take a moment to find the bluetooth (make sure its on). A list will come up, pick the right bluetooth, then it will ask for a passcode, its default is usually always 0000, hit ok and your done
Aug 09, 2009 | Pantech Matrix Cell Phone
Pairing Plantronics-E220 Bluetooth w/ my Pantech Matrix C740 Cell
Hold down the call button on the headset and wait for it to flash slowly blue. Make sure your phone is in "discoverable" mode. You should see your phone asking to connect to the plantronics headset. When it asks for a code, enter 0000.
Jan 03, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Pantech Matrix  Cell Phone Logo
383 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
