Water dispenser does not dispense water. the ice dispense is working. But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps.your help full idea include. Model number of fridge is (GE sl25jfta-bs )
  • Jurgen Oct 18, 2012
    sorry - supposed to be a Hotpioint fridge HSS25GFPA- iI don't know how it eneded up in the washer section
  • 112 Answers
Behind your crispers is a water tank or a coil of water tube. water stays in there until you call for water. that is y u have cold water at the door. i have seen the tank freeze up at times. u could raise the temp in your frige a few degrees and wait for a week or so to see if it fixes its self. next-- the water valve in back could be bad. it is a duel system ice maker has its own valve. to test this you can disconnect the line where it goes into the bottom of the door and press the button to call for water. have a cup ready.if water comes out there then your line inside the door has frozen. if thats the case call the manufacture because there might be a recall on that model. i have seen that on some GE'S. good luck----RON
Posted on Dec 10, 2009
Kenmore side by side model 106.5xx. The ice bucket has ice but the dispenser on the door will not release the ice. I hear a click but nothing happens. I removed all of the ice from the bucket and the...
The freezer part is working but the refrigerator part is leaking water from the left side upper corner .there is like a vent from, where the water is leaking and the refrigerator side is not cooling any hint or advice will be appreciated thanks
Sep 19, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Kitchen aid refrigerator water dispenser does not dispense water. the ice will dispense, and there is no filter for the water, so i would assume no clogging is the issue. But any ideas would be appreciated...
could be a few things. fist, when you call for water, listen for a very faint "hum" noise, if you do hear that, it is either the solonoid on the valve, or the reserve tank in the frige froze. easy way to check. pull the frige out and un-plug from power. on the back of the unit is a cover on the bottom, remove cover. the valve is on the far right as your looking at it. it has 2 solonoids on it. there are two plastic water lines on the bottom of the valve, i believe the one on the left is for ice maker, and the right one goes to door dispenser. remove the water line going to the door dispenser and put a cup under the valve. plug in frige and call for water at the door for couple seconds, check to see if water came out of valve into cup in back. if it did, the valve is ok, if no water, replace valve. they run about $50. if you didnt hear the hum i talked about, and the valve is ok, let me know and i can walk you through checking and replacing the switch in the dispenser. good luck, shane
I have a GE Hotpoint Side by Side refrigerator Model #HSM25GFRA SA and have a problem with the water dispenser. I've switched out the filter with two new ones but still have the same problem - no water...
Alot of the GE refrigerators have problems like this. You either need to replace water valve on the back because one of the valves has stopped working OR the tube in the door has frozen and the door will need to be replaced. The best way to tell is remove the hinge cap on the bottom hinge and disconnect the little adapter put a towel down there and then trigger the water dispenser. If water comes out, the tube is frozen in the door. If not, replace the valve.
Jul 15, 2009 | Refrigerators
Water does not dispense and will not make ice
yoiu need to thaw out the rfesevour inside the refrigerator with a haior drier son that the water can flow to the soilinoids and then the ice mAker and dispenser.
Apr 07, 2009 | Refrigerators
Water Dispenser on freezer door does NOT work
change filter check tap see if water is shut off may be is the water valve
Apr 03, 2009 | Admiral 26 cu. ft. Side-By-Side...
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Jun 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Water/Ice Dispenser is not working
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
