Question about Lakewood 7101 Oil Filled Radiator Heater
Need wiring for on-off switch
I have a Lakewood heater that has 7 fins excluding the front where the controller is mounted.
I need a wiring diagram for the on-off switch. I have a bad switch, removed it last year and now I want to hook up the new switch, but I only find the black wire going to the plug. I don't see where the other wire is to hook up to the switch, please help! TIA
Joe
  • 10,865 Answers
Hi Joe. Typically the switch interrupts the hot wire, which is black. Therefore, two black wires are connected to the two screws on the switch. Look in the area where you see the one black wire and you should find a second black wire. Connect each of the to the switch and you will be switching [controlling] the hot [black] wire.
Posted on Dec 10, 2009
Testimonial: "Thanks for the quick reply, I located the other wire while waiting for the response. You were right, thanks again. Joe"
Model #70001A controll switch melted
you can go to this web site to purchase a new control board. You will need to test the heater element to make sure that it's not shorted to ground. If you need more help with this just respond to the e-mail you receive also be sure it is unplugged before testing and short out the end of the plug if it's not hard wired into the wall. here's the site.
http://www.officeworld.com/-/70001a-lakewood-heater
Jan 27, 2010 | Lakewood Heating & Cooling
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Switch burned out on Lakewood radiator heater.
Hi, go to amazon.com and you can get a switch for the Lakewood model 905 heater.Best of luck,
Shastalaker7
Nov 24, 2009 | Lakewood 905 Radiator Heater
I need a wiring diagram for a lakewood 5500
Visit this page for service center info and or parts: they should be able to help you http://www.lakewoodeng.com/html/parts.html
Feb 13, 2009 | Lakewood Oil-Filled Electric Radiator...
ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Aug 27, 2008 | Lakewood Heating & Cooling
Dayton model 3e473a
there's a high limit switch inline with the motor - may need replacing.
Dec 26, 2007 | Heating & Cooling
Lakewood 7101 Oil Filled Radiator Heater Logo
528 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
