Question about Bosch Nexxt 300 Series WFMC2201UC
There is a plastic piece under the top that is connected to the drain line. It looks to be all clogged up and the waher won't drain. How can this be cleaned out?
  • 33 Answers
Use a piece of wire maybe a coathanger or something. or a plumbers snake might work or maybe some wicked cleaner stuff like draino might work but that might be bad for some plastic. vinagar works too but take a long time overnight at least.
Posted on Dec 28, 2009
Won t drain
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Oct 22, 2013 | Bosch Dishwashers
I have a Kokler tub which has a toe tap drain that is clogged. I turned the metal portion of the actual toe tap counter clockwise and removed the top portion and the rubber piece directly under it. Now I...
Someone overtightened the plastic part during installation. There is a threaded portion at the bottom of the plastic cylinder that screws into the actual drain. I have never had to resort to pliers for removal but that approach may be your only hope for removal.
May 11, 2017 | Delta Home
How to clear drain line on refrigerator
i have had luck cleaning refrige drain lines in 2 ways,make sure theres no ice in the drain line just below the freezer drain pan,then try a piece of plastic hose available from any hardware or home stores and feed it down the drain under the drain pan and blow into the hose to pressurize the line it may dislodge the blockage,if not,try a piece of wire and rat the line out till water drains
Feb 20, 2012 | Kenmore Top Freezer Refrigerator
Water backs up and out of the detergent/bleach tray
open the door and look at the top like at eleven oclock,you'll see a plastic piece sticking out the rubber boot,check that and see if anything is stuck in there or around that area,that's where the water drains out from the tray or you could have a clog somewhere else in the line but two times i've found a sock stuck up near that plastic piece
Dec 03, 2010 | Kenmore HE2 Plus Front Load Washer
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
On the top back of the fridge is a unit that seems to be connected to the freezer. It leaks intermittently into the refrigerator and pools under the crisper baskets as well as wetting food that is on the...
Looks like you have a clogged drip tray channel. Unplug the refrige ,leave freezer and food compartment doors open for at least 12 hours. After that look under behind the refrige for a plastic-rubber tubing ending in the drain pan under the refrige.That is clogged, get a 2 feet hose 1/2 inch diameter. Attach end to the drain tubing then blow through this will clear the way.. and your done.
Dec 31, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Have kenmore model# 58714249990. it won't drain out.
The first thing to check is that the drain line isn't kinked. If it goes into the drain under your sink. Check that the garbage disposal isn't clogged (run it once with half a sink full of water). Check the drain vent for clogs ( its the black plastic piece of pipe that runs up and down near the back under the sink.
Hope this helps Ya,
RSMITH972278
Oct 13, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Does not drain,
HI,
check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line...
thank u
rate me!!!
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
2. Water Pump
May 31, 2009 | Maytag Washing Machines
Cleaning or unfreezing a drain in bottom mount freezer refrigerator
The drain for a GE bottom mount refrig is located under the plastic panel at the bottom of the refrigerator compartment under the crisper drawers. There are two plastic pieces, one is about six inches long and runs the width of the refrig compartment which is right at the door seal. This piece is held on by two plastic tabs located approximately an inch from each end. By inserting a small srew driver under the panel and lightly prying up you should be able to pull the panel straight out. The the other plastic panel can be easliy pulled out. Under the styrofoam cover you will see the drain behind the evaporator fan. It is a two inch by four inch metal valley pan at the back wall which feeds to a black pipe at the bottom and in the back of the refrigerator. If you are having problems with ice clogging the drain and stopping the fan blades from turning, chances are it is either the defrost thermostat (mimetal switch) or the defrost timer.
Jun 06, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
Bosch Nexxt 300 Series WFMC2201UC Logo
42 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
