Question about Lexmark Wheelwriter 6 Series II Typewriter
MY GRANDSON WAS "TYPING" AND NOW WHEN I AM TYPING, SOME OF THE LETTERS ARE GOING OVER THE PREVIOUS LETTER. WHAT DO I DO TO FIX THIS PROBLEM?
  • 3,741 Answers
It happens when the carriage does not move or some of the key is stucked up.
check all the keys properly.also see that none of the key is loosened up too.
try pressing space key and type single letter and again press space key and type a single letter --do this few times and check if it has same space between all the letters.if between some letters the space is short .then there is the problem with the wheel assembly that needs to be checked.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Dec 10, 2009
I am setting up a Vision 1 action camera DragonTouch 1 for my grandson. How do I format the SD card that I purchased for tllhis?
Most SD card will fit in your laptop or tablet with an adaptor sleeve. Most laptops today automatically format new memory cards or prompt you to do so. Look on the side of your laptop or tablet for a hole about an inch by 1/8 of an inch slot. Insert the sleeve and follow the instructions. You can go old school and use the command prompt window and drive letter using the command help from the C:>
type help from the C prompt to see the proper commands
example
C:>format D:
or
C:>format E:
etc..
***make sure you have the correct letter or you will clear all the data from whatever letter you use.
Jan 10, 2018 | Action Cameras
Cursor jumps around and inserts letters in words I have typed
Run a spyware, Malware program, SpyBot- 1.62 or Malware Remover, LAVASOFT, and more... clean out the machine.
Jan 04, 2010 | Dell Inspiron 6000 Notebook
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Learning to type a message
It must be on predictive text. Basically you type the numbers according to any of the letters that are there.
So for example, if you wanted to type "Hello"
It would be 4(H) 3(E) 5(L) 5(L) 6(O)
This will show a word it thinks it can make from these numbers, generally by pressing the star key, you can flick through the options of words. If your word isn't there, you will have the option to type it in manually. For this (using the same example) you would have to type
44(H)
33(E)
555(L)
wait for a bit for the cursor to move over
555(L)
666(O)
You can see that predicitve is much faster.
I hope i fix ya problem :)
Apr 15, 2009 | Motorola Mobility RAZR V3
Can anyone explain this icon that has appeared on my phone after my grandson was playing with it it has a letter G then a bar with sides and an upward arrow
do not worry. your grandson has caused no problems. this refers to the type of signal you are currently recieving. This icon means "GPRS" signal which, for lack of a better term, means you have a stronger signal than if you saw the letter "E" in its place. the timing was most likely coincidental.
Mar 19, 2009 | Nokia 6030 Cellular Phone
Only part of the character types on the page
EITHER YOUR RIBBON IS FAULTY OR THE RIBBON DRIVE ON YOUR MACHINE IS FAULTY. LETTERS ARE PRINTING ON PART OF SAME RIBBON AS PREVIOUS LETTER
Jan 28, 2009 | Olympia Supertype 330 Typewriter
Scrambled letters
if it is an acer press fn and f7 that should fix it
Oct 09, 2008 | Acer 91.63X07.001 Keyboard
Message writing
When you punch in the letter on top screen there is an option of how you want the letters to come up. the 2 top green bottoms will help you to choose.
It says somwthing like alpha, multi-tap, numbers. If you choose numbers and press # 2 will come up.
If you choose multi tap and press # 2 once letter A will come up, if you press 2 two times letter B will come up and so on. Once the desired letter comes up wait till the cursors stop blinking and it will move so you can time the next letter or you can move the arrow to the right for you to type the next letter.
If you choose Alpha (or the other choice left) and you press # 2 and all the crazy letters will come up, I undeerstand, if you see letter ok for A it will stay and you can go to the next letter, for the next letter you press # 3 you get letter Bor crazy letters for that key, you move the arrow cursor down and it will show you all the letters you have in that key, you can scroll dow and the press ok on the letter that you need. What happens is that the phone has many words for each letter you type and is helping you to make the words. This used to be confusing to me as well, If you play a little with the buttons you will get it. Try to set in for multitap, it is a little easier.
Artgirl
Jul 18, 2008 | Nokia 6101 Cellular Phone
Lexmark Wheelwriter 6 Series II Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
