Question about Acer Aspire 5500 5570-2609 Laptop
My computer restarts alone ! on/off ? - Acer Aspire 5500 5570-2609 Laptop
  • 154 Answers
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
Posted on Dec 10, 2009
    Problem Solver:
Hi . i installed windows 7 , this is my first time i use it , and everythings Working Good , without any problems , but i have problem and dont know if its from software or hardware , that is the Pc restarting alone and autumatically without any Oreder and dims ... i asked some one about this Problem and they're told me the reason of this Problem (RAM) Or (Power Supply) and i am still not sure and the Problem still working .... can anyone help me plz
Posted on May 09, 2010
  • nartabzakh May 09, 2010
    thank you nicole , i checked the CBU temperature its 43 i think its hot ,,, but i checked my old Pc temperature it was 50 and working Good with small problems ,,, this is new Pc and have many problem with ,,, do you think the problem by power supply or cooling system (Fan) or Ram ,,,,, is it hardware problem or software problem ,,,
    thanks
    thank you nicole , i checked the CBU temperature its 43 i think its hot ,,, but i checked my old Pc temperature it was 50 and working Good with small problems ,,, this is new Pc and have many problem with ,,, do you think the problem by power supply or cooling system (Fan) or Ram ,,,,, is it hardware problem or software problem ,,, thanks
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
43code error
(Laptop) unplug the power cord, then take out the battery, unplug all usb devices, leave it alone for a minute or two and then replug the power cord and then the battery. Turn the computer on and restart as normal. replug in your usb devices and they will reinstall as usual
Sep 30, 2013 | Electronics - Others
My nv79 notebook charges up my battery to 100% the charge light turns blue and after 1 minute cuts off and requires restarting to start charging again
Try removing your battery and power on your computer with your power cord only. If you have no problem with the power cord alone, then you need to replace the battery.
I hope this helps!
David
Apr 02, 2013 | Gateway NV7915u Notebook
The printer show offline
Is this network printer or stand alone printer?
For both, check the power of printer.
For network printer, check print server is working, network cable from printer to print server is fine, check your computer connect to network.
For stand alone printer, check cable connect between your computer and printer.
If they are all good, restart your computer to let windows pick up your printer when it start up.
Hope this will help. Thanks for reading
Jul 18, 2011 | Office Equipment & Supplies
It turns alone and have to restart by main svish
type *#06# ,if it display an 123456.......... IMEI .it is an RPL problem and your phone serial number is corrupted
Jun 05, 2010 | Nokia 6288 Cellular Phone
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
Laptop wont boot up
Stay away from Emachines in the future. Pay another $100 and get a real computer.
1. check that nothing is in the CD-Rom drive and restart the computer.
2.Shut down the computer. Unplug the AC power. Remove the battery pack. Wait 2 minutes or until machine cools.
try powering on comp on battery alone, then try with AC power alone.
Dec 26, 2009 | eMachines eMD620-5133 Notebook
My computer is getting really slow. I can't get my stuff or send messages fast enough.
go to http://www.piriform.com/blog/?filterBy=Defraggler and download defraggler and ccleaner. Install and run them, first ccleaner cleanup and registry fix and then defraggler. This will help tom speed up mthe pc, then do a scandisk (part of windows in the 'my computer' right click on the c: drive, click tools and then 'error checking check now'. Put a tick into both the request boxes, say yes to scandisk on re-start. Restart your computer and leave it alone until the computer restarts. Could be a while! Patience! nThat should do it!
Dec 06, 2008 | Microsoft Windows XP Professional With...
Acer Aspire 5500 5570-2609 Laptop Logo
458 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
