Removing bowl on fisher & paykel washing machine
Can you provide instructions for removing the bowl from the tub on a fisher & paykel smart drive pride 5.5 washing machine
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
  • 868 Answers
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Posted on Jun 08, 2008
SOURCE: Our Fisher and Paykel Pride
Sounds like your pump is blocked. **UNPLUG the machine**. lift or drag the machine to a spot where you can let the water dump out. The water comes out fast and makes a big mess. Tilt the machine back. On the front-right underside of the machine you will see the pump with the fan hanging down. Unplug the white plug and the earth cable from the back of the pump. You might notice that there is a white plastic clip that you can move to the side. Hold the clip out and twist the pump clockwise. At this point the pump will drop out and water will go everywhere. Try and take the pump out kinda fast so that the coil does not get too wet while the water is dropping out. you might find a blockage (coil, hair clip, underwire etc) sticking out from where the pump impeller sits. Pull out your blockage and check that the pump spins freely when you spin it by hand. If it does not spin freely you need a new pump.
Now, after you unblock your pump, you can put it back together the same way you took it off. Make sure the white plug is not wet before plugging it into the pump and make sure the pump coil is dry too! use a blowdryer to dry for a minute if unsure. When twisting the pump back in, the wires should be at the back of the machine and the earth cable is kinda close to the rotor (motor). Make sure the pump is sitting flat so the seal works too. That clip should click lock back into place to hold the pump from turning. The washer will not spin until all the water is out in case you are wondering. Hope this helps!
Posted on Aug 02, 2008
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
Posted on Apr 20, 2009
  • 69 Answers
SOURCE: How to I get to the pump on my Fisher & Paykel
If machine has water in it, bucket out as much as you can.
To access pump:
-Pull machine forward and lean it backwards so you can access under machine.
-On the front right hand side, you will see a fan blade- this is the drain pump. This fan blade should spin freely if you turn it by hand.
-To remove pump: remove plug connection that has 2 wires. Remove other plug connection that has 1 wire. On the top of the pump assembly, you will see a white plastic tag, about a 40mm long horizontally across the pump- gently pull tag towards you, and turn complete pump unit anti clockwise- whole pump will drop out (don't force it, it should come out easily) *Note* if there is water in machine still, it will come out when you remove pump assembly- be ready with some towels!!
-Check pump impellor(blade on other end of pump) is free from obstruction, and turns easily. Check with your finger to see if there is any obstruction in the hole where the pump has come out of (inside bowl).
-You can test pump with an ohm meter (should be approx 37ohms from memory)
Reassemble and test for leaks etc
Posted on Aug 11, 2009
0 characters
1 Points
Hi where can I get a instruction manual for my washing machine
go google and type in -- owners manual for ( make and mode ) fisher and paykel washing machine
if it is available there will be a pdf version down load
Oct 26, 2015 | Fisher and Paykel Washing Machines
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
Is there a filter on the smart drive 051- my washing is coming out with dirty black marks
if the black marks come out then it is lint. put 2 pkts bicarb soda into empty bowl, select hot fill, select high water, start cycle. let it wash for 10 min"s , turn machine off, leave overnight. restart cycle in the morning, that should clean tank and bowl. please reply 4 more help.
Apr 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel smart drive starts & fills but as soon as it trys to wash, the tub slightly goes round then it starts error beeping. I tried to spin it, it will rinse but not spin does the same...
just below the wash tub there is a very sensitive sensoer over time it builds up with dust and at the ends youl find slite corrosion clean the sensoer and it will be fine also clean any rust of the capstan rim for more detailed instructions feel free to email my company
Apr 21, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel smart drive 503 top loading washing machine
while under the lid there should be a tech sheet, explaining varions flashing light codes and there respective fixes for each instance, replacing tha switch(out of bal switch) seems like a good start though. cant remember if jumping it out will help, might be looking for a break in the line rather than continuity through it
Oct 31, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
260 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
