Question about LG enV3 VX9200 Cell Phone
My LG EnV3 turns off & when i try to turn it back on the small screen goes blank every couple of seconds .. & it wont charge either
My lg env3 all of a sudden wont turn on, one day i was charging it and i shut off and wont turn back on??
First thing to do is check the battery or try to replace another one and see if its just the problem. might need for replacement cause you may using it for a long time or you might left it overnight charging.
Also check the charger if can filled up the battery content.
Jun 14, 2011 | LG enV3 VX9200 Cell Phone
Text message goes blank
turn off you phone then on it again or try to remove your simcard then back it again if not reformat your phone
Jun 24, 2010 | LG enV3 VX9200 Cell Phone
How do u fix blank screens on the LG ENV3? the phone works and everything but the screens are blank! how do u fix that?
Hello
Its not possible that you can get correct code free. Its comes from server & based on your IMEI. Entering wrong code can missed your tries limit of unlocking
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with any single network, you can use your in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry like Verizon
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com/
May 12, 2010 | LG enV3 VX9200 Cell Phone
My LG env3 cell phone won't turn on?
That happened with my phone, I was texting while in the shower(not smart) & it messed it up. On the front and inside screen it would turn to the Verizon Wireless screen, but then as if it were to switch to the actual wallpaper i had it set to, it would white out for .5 seconds, then turn to the same Verizon Wireless screen, what I did was plug it into the charger, turn it upside down, leave it like that over night, and it was perfectly fine. It's ironic that I'm going through this right now:/ haha.
Feb 15, 2010 | LG enV3 VX9200 Cell Phone
My phone won't charge or turn on. I plugged it into the usb drive, and it tried to sync to the computer, and i remembered i have to turn it off before it would charge and not try to sync to the computer. I...
try to get a new charger or battery if that does not work then i suggest a new battery....... of there is no luck then ask the verizon people... if they tell you to get a new phone then throw a fit and that (most of the time) works :)_
Dec 24, 2009 | LG enV3 VX9200 Cell Phone
Env3 turning off by itself, and then not comming back on.
My wife was having the same problem. She got a software update from Verizon, but it still continued to turn off "randomly". So I looked on the LG site, and a member said the issue is actually that the battery is losing contact with the phone when small amounts of pressure are applied to the back of the phone, like when picking it up, setting it down, pressing OK on the front, etc. His solution was to carefully lift up the four contacts in the back of the phone so that they make better contact with the battery. I tried it, and surprise, surprise, the phone has not shut off since! I would suggest doing this very carefully though, since the contacts are very small and thin. Good luck!
Sep 07, 2009 | LG enV3 VX9200 Cell Phone
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Aug 15, 2009 | LG Prada KE850 Cellular Phone
LG enV3 VX9200 Cell Phone Logo
480 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
