Question about Compaq Evo Workstation W6000 PC Desktop
Compaq Evo W600 reboots after POST. windows XP Pro
Compaq Evo W600 reboots just as windows XP Pro loads whether in safe mode or not. I just switched from SCSI drives to an IDE drive. Safe mode it reboots after the DOS list finishes, or at the windows logo screen on regular boot. Capacitors are all fine, PSU is tested & fine. I can't find a problem or reason for the rebooting. Any ideas?
    Problem Solver:
  • 10 Answers
Delted.
Posted on Dec 11, 2009
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Yeah, my laptop will boot all the way up to my desktop, but when i go to open up my files they won't open. plus, recently, it takes forever or never for my desktop to completely load. when i put my...
Not a driver, you have a corrupted program on the boot list. The safest way to solve this is to recover your files from Safe Mode and reinstall. Then reinstall your programs one at a time with reboots in between. If you feel something has changed in between reboots then the last program installed is bad, get rid of it.
Aug 12, 2010 | HP Compaq Evo n610c Notebook
I have a HP Compaq Evo D51S and when every time I turn it on it displays a message saying that Windows did not start successfully. It appears that it is stuck on a loop, it goes through the normal...
You have removed any system file or driver from your PC or your system have many of viruses. Start windows in safe mode by clicking F10 while booting. Transfer your files from C drive to other drives or in removable drive. Get windows recovery disk and repair your windows xp. This also formates your C drive. Next time, load a licenced antivirus and do not make any changes in C drive.
Jul 24, 2010 | HP Compaq EVO D51S Intel Desktop PC -...
I am attempting to run a compaq EVO d510 with a recently imaged 160 GB hard drive. It flashes blue screen of death and reboots after loading agpcpq.sys. I think that the most advanced hard drive mode is...
If the image on your hard drive doesn't have all the right drivers for your system, it won't work, and you will get BSOD. can you boot into safe mode? If so, you may be able to uninstall a driver or two...it usually the last driver/file that successfully installed, not the one that doesn't finish loading, so see what the file "before" agpcpq.sys is. If you have a windows XP cd, you can try to get into the recovery console and then the command prompt, and typing "fixboot" ...or you can run the system file checker "sfc /scannow" ...but without more information, you may end up wiping it. Do you know what drivers are on the hardd rive?
Jan 12, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Xp pro will not load
HELLO THERE:
when you start the computer hit the f-8 key repetedly and the xp pro advanced boot screen should show up now select last known good configuration that worked then hit enter and the computer will reboot and hopefully this will get you going also make sure there is no cd rom in the drive ok? please let me know how this goes there is more we can do if needed please dont forget to rate the solution i have provided this helps me out as well
best regards mike
Aug 06, 2009 | HP Pavilion N5350 Notebook
Cant get windows xp to load
Hit F8 while it is booting up and take it into SAFE MODE if at all possible. From there run an error check.
Go to My Computer - right click on C: -- go to properties - then select Tools - error check. Make sure you check the two boxes to have windoews fix the errors as they are found. The error check should run after you restart your computer.
if it still doesn't load.. reboot while presssing F8 and take it into safe mode and use SYSTEM RESTORE to restore computer to earlier date.
Go to:
START - ACCESSORIES - SYSTEM TOOLS -- SYSTEM RESTORE. and then select a date computer was working ok.
May 27, 2009 | Compaq Evo N600c Notebook
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Compaq Evo W600 IDE HDD Installation Problem
REFORMAT THE HARD DRIVE LONG FORMAT NOT QUICK AND NTFS....THEN ALL SHOULD BE WELL AT REBOOT.RICHARDM69
Mar 10, 2009 | Compaq Evo Workstation W6000 PC Desktop
WINDOWS XP PRO SERVICE PACK 3
First off, please use proper case. All upper case makes it look like you are shouting. Thanks.
Try removing everything you can possibly remove from the outside other than the monitor. Remove any cards inside not needed to boot (sound, NIC, modem, etc.).
Disconnect mouse and keyboard, too if it will boot without a keyboard. Some systems will halt at the BIOS screen without a keyboard.
When you have a minimum config for booting, boot and see if it stays on. If so, one of the items disconnected is the culprit.
If not, reconnect keyboard (if disconnected) and boot into Safe mode by tapping F8 after BIOS screen. See if it will stay on in safe mode. If it will stay on in safe mode, problem is O/S.
If it won't stay on in safe mode, see how long it will stay on at the BIOS screen. If it will stay on indefinitely, you could have flaky RAM or possibly hard drive. Power off, unplug power cable, remove hard drive and see if you can boot to the Windows CD. If it will boot up to Starting Windows and stay on, probably not RAM although that is not a definitive test. At that point, I'd try another hard drive and see if the O/S will install or try wiping and reloading the original hard drive.
Let me know if you need more help.
Honest1abe
Jan 17, 2009 | SuperMicro Pentium III Xeon (TMR-004)...
System will not load, keeps restarting ,will not go into safe mode
it may be cycling, when the system reboots, press and hold the power button, to completely switch off, then turn back on as normal
Aug 17, 2008 | Compaq Presario 5000 PC Desktop
Compaq Evo Workstation W6000 PC Desktop Logo
179 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
