Question about Lexmark Wheelwriter 1000 Typewriter
How to delete memory on RePrt
We need to delete the keystrokes that are stored on the RePrt key, or how can we stop the machine from storing the keystrokes? Will turning the machine off & on accomplish this?
  • hamiller Dec 10, 2009
    Unfortunately, pulling on the "R. Upper bail arm" did not clear the reprint, BUT turning the machine off certainly did!
    Thank you for the quick response.
    ~ Desperate civil servant
  • Lexmark Master
  • 3,594 Answers
If you pull the R. upper bail arm to activate the auto paper insertion will clear the reprint, turning it off will also do it. There is no way to stop it from storing data as that memory is also used for correction.
DickO
Posted on Dec 10, 2009
  • Dick O Reilly Dec 11, 2009
    Pulling the bail arm dosen't clear the reprint until you start typing. Sorry to mislead you.
    DickyO
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
La memoire de la machine s'est effacer comment la reprogrammer?
On the left side of the keyboard are 3 keys store, play and delete. Hold the store key, type an address 01-99, release store, type information, press store again.
To print hold play and type address, delete works the same way.
BE SURE THE BATTERIES ARE GOOD AND THE HOLDER IS CLEAN OR THE MEMORY WILL BE LOST ON POWER DOWN.!
DickyO
Jan 11, 2011 | IBM 3500 Typewriter
Broken LCD screen
menu > key 7 > key 4 > key 3 > ok Blue tooth active
Jul 14, 2010 | Samsung S3500 Cell Phone
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
How do I cancel the RePrt option?
The reprint stores info. as you type to clear it pull the R. Upper roll arm to engage paper feed, the first keystroke will start the reprint over. You can also turn it off and on.
DickyO
Dec 23, 2009 | Lexmark Wheelwriter 1500 Typewriter
Storing key strokes on IBM Wheelwriter 6, Series II
On the L. side of the keyboard are 3 keys store, play & delete.
To store hold the store key and type an address 1 - 99, release the store key and type info. press store again. To play hold play type address, release play. to delete follow same with the delete key. Be sure the batteries are good or you will lose data on power off.
DickyO
Jan 20, 2009 | IBM Office Equipment & Supplies
Can not delete address stored
press in 9 * 8 # 7 on key board press the start key use the # key to scroll throgh the options till clear memory is in the display press enter. this will clear ALL memory & reset it to factory settings
Nov 19, 2008 | Office Equipment & Supplies
Need directions to store keystrokes in Xerox 610 Memorywriter
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
Nov 12, 2008 | Olympia Mastertype 3 Typewriter
IBM Wheelwriter 6 reprint key
There is no replay key on a WW6 however there is a memory.
On the L. side of the keyboard there are 3 keys store, play and delete, to store hold store and type 01-99 as an address release thwe keys and type info when finished press store again.
To play hold play and type address.
To delete follow same proc.
DickyO
Jul 22, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
