Question about Panasonic Lumix DMC-TZ3 Digital Camera
When I turn on the camera, It comes on for a couple of seconds then a gray thing pops up that says turn your camera off and back on. It just does that over and over and never really comes on for good.
  • geofsdaddy Dec 10, 2009
    Thanks. I will try your solutions.
  • 1,511 Answers
Hello Sir,
This is the very common problem that usually occurs in some models of Lumix. Here are some tips and tricks that works sometime else you need to contact the authorized dealer for a warranty claim (if applicable).
Make sure that no button on the device is pressed inside when the device is turned on
Make sure that the battery is properly charged and is properly installed
Memory card of the device is properly inserted and locked
Try to turn on the device on some other modes.
Else the firmware of the device needs to be upgraded/re-programmed by any authorized dealer or any Professional technician.
Best of Luck,
Rate me if you found my solution helpful,
Waqar,
Regards.
Posted on Dec 10, 2009
My nikon 5200 built in flash would not pop out
Here are a couple of things to check. First, what mode is the camera in? If it is manual or shutter priority, make sure the shutter speed is under 1/250 second. Second, if the ISO setting is very high, the flash might not deploy because it is not needed. What do your pictures look like? Are they properly exposed without the flash? Also, make sure that the flash is enabled in your menu and at the flash button to the left of the lens when viewed from the camera back. Check in the menus to see if it is in the command mode by accident.
Jul 13, 2014 | Nikon Cameras
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
I can not join a game with a friend. Others can join but we can not. Y
one thing you guys can both do is turn off your system then turn off your router for 30 seconds; turn router back on then turn ps3 back on and try reconnecting with each other. if this doesnt work make sure both of you have open NAT types. Hope it helps.
Oct 07, 2012 | Ubi Soft Entertainment RUSE for...
My camera lense popped half way in. and won't turn on
take out the lens unit disaassemble the lens replace the broken/deformed parts service it assemble fix it to get proper functionning.
Apr 10, 2010 | Samsung S860 Digital Camera
Garmin won't turn on
I hope this helps, I had the same thing happen today. I noticed on the face under the word Garmin you can pop the face off and underneath on the right side is a reset button I held it down for 10 seconds popped the face back on and pressed the power button it came on. I hope this works for you.
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Happy turkey day, I have a westinghouse lcm-19w4,when I turn it on the screen flashes gray horizontal lines in the middle of the screen for a second then goes black. this happens a couple times then the...
You either have a hardware problem with your video card. ( may have pop out of socket when you plug in the monitor) or the cable is not allow communication to the monitor. As long as the amber light comes on you know you have power so focud on data cables and hardware.
Nov 27, 2008 | Computers & Internet
Olympus mji 700
It has to go back the Olympus for replacement or to seller if less than one year.
Sep 02, 2007 | Olympus MJU 400 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
