Question about HP Pavilion dv6000z Notebook
Error 100a HP error code 100a attempting to load recovery discs for Vista also "no id device" showing. Any help with this is greatly appreciated. Thanks.
    Problem Solver:
  • 12 Answers
HP uses a Tattoo system that has to be applied to the Motherboard and the Hard Drive. That error indicates that one of those is missing. You will have to get the tattoo program from HP.
Posted on Dec 10, 2009
HP recovery disks don't boot!
Sounds like you need a windows vista operating system disc. The recovery discs set your system back to factory settings like when you first brought it home from the store. But to me, the system is bloated with all the software and trial junk that you don't need. If you can get your hands on a Vista Operating System Disc, then do a clean install from it. Just make sure your Certificate Of Authentication (COA) sticker is readable so that you can activate the vista once you've got it loaded. If you can't get your hands on a system disc, take it to a computer repair shop, I would think you could find one that will load the operating system for $60 or less.
Mar 15, 2012 | HP Pavilion dv6-1030us Notebook
Trying to use HP Recovery CDs on notebook. When
This error comes because of bed indexing unit in harddisk.
For that boot your computer with recovery disk then follow the procedure then delete all partition 1 by 1.
Then create new partiton.
then fomrat 1 partition and install windows.
Try this 4 to 5 times then you can success .
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | Compaq Presario Notebook
Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
May 16, 2009 | HP Computers & Internet
Error 701 when loading recovery discs
sounds like a scratched or damaged disk try another bootable dik if it boots than that is most likely the problem.
Apr 14, 2009 | Computers & Internet
I have hp pavilion dv6000 i had a problem about recovery manager
Did you attempt to load recovery/factory image from hidden partition and if so did you follow User Manual or Guide re instruvtions? if so there should have been no problems. I would try again though do it slowly and carefully when choosing Options so that you don't change Partitions where the Default Software is.
Was it Alt and F10 buttons when powering up from a Shutdown, i.e Cold Boot?
Apr 09, 2009 | HP Pavilion dv2000t Notebook
Blue Screen trying to load XP on HP pavillion dv4-1125nr
It should have an error code in there somewhere on the screen where it says it's shutting down.
Type that error code into Google and you'll find an array of answers. There's a bunch of things that can cause the problem you listed, but we don't know which one.
Dec 22, 2008 | HP Pavilion dv4000 Notebook
I cannot enable my wireless adapter
My suggestion would be to uninstall SP1 if the wireless driver update does not work and wait until a later time to reinstall SP1 since it is apparent the problem occurred with the SP1 update. I'm surprised the HP Recovery didn't resolve it - unless it wasn't taken back to to Factory Default - which would be extreme as you would loose all data, software and updates.
Dec 19, 2008 | Compaq Presario V6310US Notebook
My computer wont go past the vista start up screen and after about 5 minutes it shows a little blinking cursor in the top left hand corner
  • First try to disconnect printer, external hard drive and other devices from the system excluding monitor, keyboard and mouse then try to start up the system. if the system can boot to windows Vista that way, just reconnect the devices and restart the system. If it has the same problem, you will need to repair the Windows Vista using recovery tools in windows vista recovery environment.
  • You will need the Windows Vista DVD to access this recovery feature of Vista. Check the Discs that HP has provided and check if you have the Disc for Windows Vista. If you do not have it, you can borrow a Windows Vista DVD (Any versions) from a Friend or co worker. If not, just request the Disc from HP Support.
**Note : You will only need two tools under Windows Vista Recovery Environment, that is Startup Reapir and System Restore.
Starup Repair - This will automatically fix errors on the operating system (If this will not work, proceed to system restore)
System restore - You can revert back the system to an earlier date where is was working properly. (No files will be deleted if you this feature)
The link below is a complete step by step of what you need.
Link - Steps for Startup repair :
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Link - Steps for System Restore :
http://www.bleepingcomputer.com/tutorials/tutorial142.html
**Note : If the Links will not work, just copy the whole link and paste it to your web browser's address bar. I Suggest that you print the steps so that you can perform the steps with accuracy.
Oct 29, 2008 | HP Computers & Internet
Unsuccessful backup. I/O device error (0x8007045D)
Try this http://support.microsoft.com/kb/952272 it will take you through your problem step by step hope it helps
Oct 25, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
1,318 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
