Keeps saying no signal once plugged in to tv - Televison & Video
    Problem Solver:
  • 8 Answers
You may be in the antenna mode, your T.V. is searching for singnal for an antenna. Switch your settings in the menu to one of the following
CABLE,HD Input,VIDEO 1,2,3.
try that
Posted on Dec 10, 2009
Tv wont get channel signal
1- Have you tried a different input cable?
2- maybe try using the set top box tuner?
3- check the input setting on TV?
Good luck
Dec 11, 2013 | Emerson LC320EM9 32 in. LCD HDTV
I've a problem. When i switch on the tv. It says no signal. I've thought of turning the satellite but it keeps saying no signal and the signal quality stays at 4%. How to do? Configuration: technosat.
firstly the satellite dish antenna must be correctly aligned to satellite you want to receive.
technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
Nov 17, 2013 | Televison & Video
My dynex lcd tv keeps saying no signal when cable is plugged in?
It sounds like the CATV portion of the TV tuner is bad--Cable band.
You may have an option---with a cable box that has the audio/video jacks for output of signal on its rear side connect to a unused video input on rear of set--go to that input and change channel via the box---BY PASS THE TUNER IN THE SET THIS WAY.
May 25, 2012 | Dynex Televison & Video
I cain't get cable or antenna to work on my 19"dynex flat screen tv to work
if it keeps saying no signal make sure all the cables are plugged into the tv
and select the appropriate input on the tv
Nov 05, 2011 | Dynex DX-LDVD19-10A LCD TV
I have an insignia 19 in lcd tv My tv was given to me broken. What it does is once you turn it on it will say please wait and then the screen will go black and that's it what should I fix to fix the...
The tv LED power light indication still on,have a solid color,but the LCD screen panel goes black?Yes,this problems and the causes is the tv Tuner signal board have a shorted part or parts some kind inside it circuitries and it dying.The tv Tuner signal board,that the board,where the incomming broadcasting tv signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Insignia NS-LCD19 19 in. LCD TV
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
Apr 22, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
No instructions! do i need a lead to detect tv signals?
By "TV" Signals, do you mean video signals? If so, the WIndows video player does a good job of playing most varieties. If you mean off air or cable TV signals, you'll need a receiver. Look at the Elgato, or similar brands. They plug into a USB port and are capable of receiving analog and/or HD ATSC signals, or cable signals. Keep in mind that digital cable signals are generally a mess to identify and sort out because they are on different digital channels and subchannels. You may need a digital to analog converter in front of your Elgato to keep from going nuts trying to fighure out where everything is.
Nov 14, 2009 | Computers & Internet
No carrier signal
Your area TV stations may have already switched to digital. If that's the case you will need a digital converter box. I'd check with your local stations to find out.
Mar 19, 2009 | Orion 19RTLB (Black) 19 in. Flat Panel LCD...
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
