Dryer runs, heats for 8 to 12 minutes, cycles off burner for approx 20 min. Then follows same process. Clothes are basically "air drying".
  • 112 Answers
If it is a gas dryer check your vents there is an obstruction some where. to test this you can disconnect the vent from yhe dryer and tyr drying a load.
Posted on Dec 10, 2009
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Dryer will heat when put on 70 minute cycle but will not heat total time. if you put it on 20 minute cycle will not heat at all.
Hi, Some dryers have a cooling cycle that lasts for 20 minutes to cool the drum and its contents so you don't burn yourself when getting clothes out.
alot of machine have a max drying time of 120 minutes 20 of that will be for cooling so 100 mins hot!
the cooling cycle is usually indicated near the end of the dial in a different colour to that of the hot cycle.
Hope this helps.
Feb 11, 2011 | Dryers
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
Gas dry is not heating enough to dry clothes
There is two possible causes. Either your gas coils are going bad late in the cycle or your venting is restricted. I would go outside check to make sure you have good airflow. If you have good airflow outside the only common cause of gas dryers failing to heat late in the cycle would be gas coils. If you have a peep hole on your dryer look in it after your dryer has been running for approx 30 mins and see if the ignitor glows and then shuts off. If the burner does not kick on then you have bad gas coils. They are part number 5303931775.
Let me know if this helps _MJ_
Jan 29, 2010 | Maytag MDG2600BWW Gas Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a LG front load dryer only just 2years old and it takes several cycles to dry clothes. It seems to heat but not to its potential on high settings. It took 4 hours to dry a load of towls. I had it on...
Hello Kimwbarrym,
Maybe I can give you a few ideas on some things to check. As a general rule of thumb, to get maximum support here at Fixya, you should always include the brand and model of your appliance.. That helps us to tailor responses to your specific problem.. Anyway, regardless of dryer model, they all pretty much operate in the same basic manner and that is.. there is a heat source ( electric dryers use an heating element similar to an electric stove) A gas dryer is essentially the same but uses gas with an igniter to create a flame on a burner..) Outcome is the same.. Heat
Once heat is established, you need to move the clothes and the air thru the dryer compartment to optimize the drying efficiency. Both gas and electric models use a blower to move that heated air thru the compartment and out thru your vent system. If anything restricts air movement ( lint, blockage or any restriction in the blower or filter) your drying efficiency drops way down and dry times go way up. So. now you have the basics on how a drywer works.. Having said that... you need to check the basics first.. Make certain that you dryer exhaust system has NO restrictions to air flow.. you may have to detach vent line and check it for lint or anything in there.. If you have an electric dryer.. you can turn it on for a minute or two with the vent linbe disconnected to see if you are getting robust air movement.. If you aren't , then your problem is internal to the dryer, If you are.. you may have an exhaust duct restriction. Although not recommended, you can do the same for a gas dryer in a well ventilated area just to check the flow intensity.. But.. only for a short time since the gas burn byproduct is unhealthy for you to breath. I forgot to mention that the drum inside the dryuer should be moving the clothes during all this.. that acellerates the dry cycle too. Lastly, you need to make sure you are getting heat.. You can start a dry cycle with the dryer empty to see how warm it gets.. It should get fairly warm. Not sure I helped you but you now have a few things you can try. If you continue to have problems with this, feel free to contact me via this forum but please include the model number of your LG appliance..
Regards,
Rick
Dec 02, 2008 | LG Dryers
Clothes warm but not drying
did the coils help at all?? sounds as if its cycling to quickly, forom perhaps a bad cyclyng thermostat or a thermistor(usually would so an error code of e1--e2), you sure this is set for correct tyoe of gas,, lp/ natural???
Apr 12, 2008 | Whirlpool GGW9200L Gas Dryer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
