Turn on, turns it self off, even though the battery has been removed, and just running from the mains. I am not wanting to spend loads
  • IQUIT May 11, 2010
    OK, for specific advice, we need details.
    Brand and Model of the system?
    What version of Windows?
    When turned on, do you see anything on the screen, or just a Flashing Cursor?
    how long from power on till turns off? a couple seconds? a couple Minutes? Hours?
    If it turns off Fast, are there any LED indications that flash (The LOCK LIGHT LEDS are often used to display error codes?
  • 31 Answers
Sounds like its getting hot and machine is set to auto restart when turns off unexpectidly remove the auto restart setting and see what happens make sure all fan ports are clean and not blocked in any way
Posted on Dec 12, 2009
    Novelist:
  • 225 Answers
Check if extreme heat emits on the laptop keyboard area, if heat is present then replace the heatsink fan.
If no heat issues. Check how many RAMs you have, remove 1 RAM first and check if you can or system works fine running on 1 RAM only.
If still shutsdown then test RAMs one at a time on each slot.
Posted on Dec 11, 2009
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Tip
"Self-winding" Automatic mechanical watches that don't run.
Many questions are posted about watches that don't run or just run for a few seconds or minutes. If it's a quartz/digital watch you need to have the battery replaced. If it's a mechanical watch - even a high end "perpetual" watch like a Rolex, you'll need to manually wind it. Self-winding, or automatic, watches have a rotor in the case that spins as your arm/wrist moves throughout the day. The motion of the rotor winds the watch. When the watch is left unworn for a day or you spend your day just reading a book or otherwise remain inactive, the watch runs down. To restart it and provide a power reserve, simply wind the watch manually by turning the crown clockwise about 40 turns. It should run fine as long as you stay active. If you don't wear the watch everyday and don't want to have to wind and reset it every time you put it on, you can buy a watch winder to keep it moving. You can find them for under $100 on ebay for basic models and for more money you will see ones that wind multiple watches and have nice decorative cases.
on Apr 15, 2010 | Watches
My old amilo 7400 seems to be dead. There are no lights even though it is connected to the mains power.The battery has not charged well for some time, so I have had the PC connected to the mains power,...
you can use your pc on mains but there is no surge protection and there is no time to save anything if the mains shuts down
replace the unit with a new one
Apr 26, 2017 | Fujitsu Siemens Computers & Internet
Can not turn off and volume turns down by it self changed batteries in remote
Need more info to assist you with the issue. Does the tv work except the volume turns down by itself even with the batteries removed from the remote? If so its either the Tact switch for the vol down has an issue or the main board has an issue. If the remote wont work the tv properly either or not at all too then i would say the main board is causing both conditions. If you require further assistance please let me know.
Jan 01, 2013 | Samsung 50 in. Plasma TV
My Olympus Digital Camera D-460 ZOOM will not turn on , even though I put in new batteries
Did you notice if the batteries you took out had any corrosion on them, if they did, the camera contacts probably have corrosion on them as well. try cleaning them with a Q-tip or the eraser tip of a pencil.
If the contacts are clean, you probably have a main board problem and you need to decide if you want to spend the money to repair it.
Sep 26, 2010 | Olympus D-460 Zoom Digital Camera
Our xerox workcentre 4150 is stuck in a self test mode. We have turned off the machine and unplugged it several times, and it keeps going back to the message Please wait....Machine self test in progress....
You will either have to take off the back cover and remove the memory battery. One of those round lithium batteries and reinstall it or go to xerox.com, download the newest level of firmware and load it to the machine.
You may also want to try turning the machine off. unplugging the hard drive and see if it works like that.If it works without the hard drive replace it. If all those steps do not work replace the main board.
Aug 13, 2010 | Xerox WorkCentre 4150 Black and White...
2002 Passat won't start. will turn over but won't catch.
common problem ... have battery load tested you will find that it has enough amps to run the starter motor but not enough vlots when cranking to operate the computers correctly. VW's are voltage hungry and even though battery will crank it the voltage will fall off.
Mar 18, 2009 | 2002 Volkswagen Passat
MY COMPUTER DOESN'T EVEN START, BUT THE LIGHT THAT TURNS ON WHEN THE COMPUTER IS ON IS ON...EVEN THOUGH IT IS OFF
hmm
try 1.) unplugging the sytem
2.) open the side panel
3.) remove the battery on the main board
4.) press the power button for 5 seconds then release
5.) put the battery back in
6.) put the side panel back on
7.) plug in the system
8.) turn it on
9.) when the screen loads enter the setup menu
10.) load the default settings
11.) your done
Jul 20, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
