Hi bweddings
I would need to know which side of the power supply(primary/secondary) you are using for ground reference.
Try measuring the voltage between the emitter and collector of the horizontal output.
I`ll be waiting for your reply.
Providing you are using the correct ground 60 volts D.C. is an incorrect voltage to the horizontal output transistor. It normally should be between 120-150 volts. I suspect the power supply regulator circuit.
Pwb Assy board #6871VPMA32C $307.67 Encompass Parts has 1 in stock 1-800-638-3328 $25.00 core refund
http://www.amazon.com/Zenith-C27V36-Direct-HD-Ready-Metallic/dp/B0000SWDRK
please open it your answer is here
good luck.
Zenith C27v36 set will not come on 60 volt present on horizonal output
