Question about NEC Versa LX Notebook
No sound when i turn on the computer the sound does not start . nore does it work when i need sound i think i have tried everything . ie .. control panel my name is dave . i have a versa lx note book
  • 49 Answers
If you already tried everything probably you already find the solution.... nah im just messing with you ^_^.... usually the problem of people and laptop sounds is when they reinstall the OS of the unit and forgot to installs the drivers.... try that one out and hope it helps you... the laptop driver is in the CD comes with the unit when you bought it...
rank me if this helps....
Posted on Jan 20, 2008
Hi, I have a problem with my neo laptop. There is no sound from the internal speakers. I have uninstalled and reinstalled the audio driver and checked that it is up to date. There is only a brief muffled...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | NeoWave PC Audio Graphic Equalizer...
A few months ago my acer aspire 5100, all 3 usb ports stopped working. Now my computer does not even start. I have tried switching it on... somtimes the speaker makes scratchy noises otherwise no such...
It does sound like a complete motherboard failure, do you have a recovery disc for the laptop? remove the hard drive and leave it out, remove one stick of ram, remove the main battery, and remove the wireless card. Now fire up the computer to see if the acer logo comes up and then it should go to blank screen with the cursor blinking, if it works to this point, turn off computer. Now install the hard drive and load the recovery disc, make sure the boot sequence is set to start the dvd driver first, if everything works and you have full control we are starting to get somewhere, if it fails, this is where I would change the hard drive and see if that makes the difference, if it does, replace the ram and wireless card back into position, and last the main battery. If all this fails it leaves the motherboard as the problem. one thing I forgot to mention swap out the ram if windows freezes.
Jan 08, 2011 | Acer Aspire 5101WLMi Notebook
I have an issue with a has windows xp pro on it . when i turn it on and try to open the ie nothing happens , also when i right click on my computer and go to properties nothing happens although on...
firefox is far less prone to problems than IE because it doesn't allow these internet programs/spyware codes to run. I'd ditch IE
To get it back to normal click on control panel >internet options>
delete history and temp files and cookies, on the privacy tab makes sure disable toolbars.... is ticked
on programs tab click on manage add ons and remove everything, you can always get what you need later.
on advanced tab click on reset.
install something like microsoft security essentials to protect your system
let us know if this works :O)
Jan 14, 2010 | Microsoft Windows XP Professional With...
I have windows XP. My computer was running slow, so I went to start menu, clicked run, typed in msconfig and meant to uncheck all the boxes in start-up, however, I accidentally unchecked all the boxes in...
Try the following steps:
Start msconfig again
on the General Tab, Select the First Option - Normal Startup
on the Boot Tab Deselect everything of the page
on the Services Tab, Click Enable All, and Deselect "Hide all Microsoft Services"
on the StartUp Tab, Click Enable All, then restart your PC
Oct 23, 2009 | Logitech X-220 Computer Speakers
Electrical windows & door locks not working
Sounds like a possible BCM body controll module has shorted out partially. I think these are only at dealerships.
Jan 09, 2009 | 2004 Mitsubishi Endeavor
My tv wont turn on now
sounds like you fried your digital board or power supply not sure need more info on what tv is doing
Dec 30, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Problems with headset and hearing anything
I am having the exact same problem today and I paired mine with a Treo Palm 700 on yesterday and it worked perfectly then. UGH!
Jul 12, 2007 | Motorola Mobility H700 Wireless Headset
NEC Versa LX Notebook Logo
48 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
