Question about Olympus MJU 400 Digital Camera
Battery charged camera will not work - Olympus MJU 400 Digital Camera
    Brigadier General:
  • 11,967 Answers
Is the battery old? Have you let it completely discharge from non-use. Batteries don't come back if that happens.
Posted on Dec 10, 2009
Canon camera is 5 years old. Eventhough battery is fully charged, the display continues to say ..CHARGE BATTERY..... now camera is totally dead .... and no display text telling you to charge batteries
Try this trick. Pull battery and put camera in a zip lock bag and into freezer overnight. Take out and install charged battery and see if there is any change. This worked with a Go-pro I had, unbelievable! Capacitors get old and dry out and these sometimes affect the charge circuit as well as batteries getting old too. Li-po batteries (yours) get old if you use them or not so it may just be an expired battery.
Jan 31, 2018 | Canon Cameras
Even with a freshly charged battery, my coolpixs570 will not turn on...are my batteries dead? is my camera in need of repair?
It could be the batteries. It could be the battery charging circuit in your camera. Try charging the batteries in an external charger that you know for a fact is working properly. That will tell you if it is the camera's charging circuit or the batteries. If it is the camera's charging circuit, it will cost less to use an external charger then to repair the camera.
Jun 25, 2014 | Nikon COOLPIX Cameras
Warning battery exhausted
The two most likely possibilities are that either the camera is not charging the battery although it indicates it is or there may be a shorted or defective circuit in the camera that is draining the battery. To test for this, buy an inexpensive external battery charger (Adorama.com has several model at low cost) and see if the camera works after charging the battery on the external charger. If it works, the problem is in the camera's charging circuit and you will be able to use your camera on externally charged batteries. If that does not solve the problem, replacing the camera may be the cheep way out.
Aug 02, 2013 | Nikon COOLPIX S200 Digital Camera
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
Digital camera not working
Battery must be ok. Check the switch contacts. Battery contacts.
Sep 11, 2009 | Fuji FinePix F401 Digital Camera
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Just Stopped working...
I have the same problem, bought this camera in probally '05-'06 and sometime in '08 it just stopped working, just recently ordered new battery and charging accessories because the battery would even charge or light up the camera's charge button. Well it's not the batteries or any charging accessories, Its The Camera, anyone else know what has happend here? I bought When it first came out @ over $700 it seemed to be worth it till it died for no reason!!
Jan 22, 2008 | Sony DCR-PC55 Mini DV Digital Camcorder
Camera does not turn on.
I had a similar problem and it was a result of the battery not charging correctly. I bought the travel battery charger and an additional battery from amazon to see if maybe the battery was just old or just not charging. I figured out that the internal camera charging mechanism just wasn't working b/c the battery charged fine with the travel charger. I like the travel charger better and with two batteries I can charge one while the other is in use. I haven't had a problem since. When you buy the new battery you still have to charge it before it's first use. I hope this works for you as it did for me.
Jan 06, 2007 | Sony Cyber-Shot DSC-F707 Digital Camera
Olympus MJU 400 Digital Camera Logo
79 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
