Belkin Router
Problem for Belkin (F5D5231-4) Router
Validating identity
By dc17 on Jan 20, 2008
I have a laptop connected to a wireless belkin router and under status it says validating identity. Why is this happening?
Same Problem
May 22, 2009
-   Perfecto!!! -   Guest
May 08, 2009
-   Just a confirmation that the solution posted by gbduo and by nosmo_king_e fixed the problem for me.-   Guest
May 04, 2009
-   Can't connect. It continues say validating identity.
-   Guest
Apr 01, 2009
-   i had the same problem but graham's solution worked great. thanks!!
-   Guest
Mar 20, 2009
-   i have the same problem too , i have a desktop with wirlles connection when i try to connect it says validating identity -   Guest
Best Solution
posted on Sep 03, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
To fix, you go into the properties page of your wireless connection, go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Graham
UK
i've tried this one, but it didn't work with my laptop
Solution #2
posted on Mar 13, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try disabling your adapter, then go into internet explorer, tools, internet options, content tab and click "clear ssl state". Now, re-enable your adapter and it should now connect.
didnt work..
Solution #3
posted on Jun 21, 2008
Very Helpful)
gbduo
Rank: Apprentice
Rating: 98%, 150 votes
Graham
UK
Was this helpful?
Yes
No
86 people thought this was helpful
Solution #4
posted on Jan 20, 2008
Helpful)
rlbstein
Rank: Guru
Rating: 87%, 173 votes
Was this helpful?
Yes
No
Solution #5
posted on Feb 13, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #6
posted on Aug 04, 2009
Very Helpful)
nerd crew
Rank: Apprentice
Rating: 100%, 1 votes
go to start than go to run enter cmd type in ipconfig press space bar / release than press enter, then type ipconfig press space bar / renew wait for new ip address should be good .
ps make sure your connected to ethernet when doing once you get new ip address your good to go disconnect ethernet
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Jun 07, 2009
Very Helpful)
semiconduct
Rank: Apprentice
Rating: 100%, 7 votes
Right,
Graham's solution worked for me. I had been able to connect previously, but the connection would always indicate that it was validating.
However, it didnt work, until I disconnected, turned the power off my WiFi, unchecked the tab in the authenticate dialog box, clicked ok, then switched the WiFi power back on, and reconnected.
I have a laptop with a Dell D630 with WiFi power switch on the side. Because I have a switch to disable the Wifi power, this seemed easier/safer, and it worked.
I didnt try to disable wifi with softwware.
thanks,
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #8
posted on Jan 11, 2009
Very Helpful)
asdfsadf
Rank: Apprentice
I had this problem on a laptop (lenovo) which i reinstalled xp on.
I tried all the other stuff like disabling 802.11 settings under properties blah blah ...but nothing worked.
To resolve i went to the manufacturer site and downloaded the latest drivers for the wireless card, and any other drivers i could. Restarted the system and the problem went away.
Was this helpful?
Yes
No
Solution #9
posted on Dec 05, 2008
Very Helpful)
kevboogie1
Rank: Apprentice
Rating: 100%, 6 votes
Hadn't read all solutions so I apologize if I'm repeating someone but all I did was go back to Belkin router setup utility, or (192.168.2.1) and clicked "wi fi protected setup". Then, I selected disable at the "wi fi protected setup (wps)" option. This seemed to work for me after I disconnected from my router and reconnected again. However, you may have to go into "view wireless networks", and then choose "change order of preferred networks" in left corner of screen. After this remove your router from preferred networks list. This will allow you to pick your router from available wireless network again, and put in your encryption code. You may or may not have to do this. Hope this helps.
Was this helpful?
Yes
No
Solution #10
posted on Apr 20, 2009
Helpful)
Karma joy
Rank: Apprentice
Rating: 88%, 6 votes
solution: remove whatever "preferred networks" are displayed in wireless netwok card's property page, n click ok. this will solve the problem. happens when u switch to a new router or use a new different SSID.
cheere
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #11
posted on Sep 09, 2008
Helpful)
JGreg
Rank: Apprentice
Rating: 83%, 3 votes
I did not find the above fix for the problem to completely fix the problem. As I did you may need to go into the properties of the rounter under the "Advanced" tab then under the "Wireless settings" remove the checkmark for "Enable WiFi" Then click on "Save Settings" This did fix the issue for me.
Was this helpful?
Yes
No
Solution #12
posted on Nov 21, 2009
Not Rated)
adibks
Rank: Apprentice
Rating: 0%, 0 votes
graham's solution worked for me also.
Was this helpful?
Yes
No
Solution #13
posted on Sep 25, 2009
Not Rated)
syed_seme
Rank: Apprentice
Rating: 0%, 0 votes
- Install modem/router with cd provided.
- During installation you need to entered/will be provided with the network key
- Or you can get the network key via accessing the router using IE. etc http://192.168.0.1
- On your wireless laptop, go to the wireless network in range
- Set the properties to have WPA (TKIP or AES)
- Type the network key  and try Connect to the wireless network.
- If still unable to connect, restart your machine, and try again.
- If still doesn't work, read the manual until you understand what is router is all about. Reading is knowledge. :D
Regards,
Syed
Was this helpful?
Yes
No
Solution #14
posted on Aug 27, 2009
Not Rated)
ITG Geek
Rank: Apprentice
Rating: 0%, 0 votes
Just figured this one out my techy friends, after spending over 6 hours following all of your suggestions and nothing worked. I decided to play with the driver, I uninstalled and then proceeded to install the driver and wallahh.... it freaking worked! I am really proud of myself. Freakin fighting with a wireless card all day!!!
Vince
Was this helpful?
Yes
No
Solution #15
posted on Sep 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi i also have a problem with my wireless connection. i tried to follow grahams suggestions but when i entered the network key it says it "should be 40 bits ot 104bits depending on the network configuration, can be enetered in 5 0r 13 ascii characters; 10 or 26 hexadecimal characters....my network key is 9 characters..what should i do....please help...thanks..marge
Solution #16
posted on Aug 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks Graham - it worked!
Solution #17
posted on Jul 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ty gbduo :)
Solution #18
posted on Jul 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
gbduo's solution worked, with a small change. i had to update the drivers of my network cards first. then it worked. not before.
Solution #19
posted on Jul 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I use the solution from:
Graham
UK
Thanks it worked....
Popular Solutions for Belkin Router
Questions and Unsolved Problems for Belkin Router
Do you recommend Belkin (F5D5231-4) Router?
Answer
Answer
we have lost connection from our lap top and the wireless light on the router is out. i hope you can... (More)
Answer
How do I get my new iPOD touch to surf the web thru my Belkin 54 G Wi-Fi Router? The iPOD appears to... (More)
Answer
My computer is not allowing me to connect to the router wirelessly.
Answer
4 port router - easy install wizard step 1 - 'multiple network adapters found - choose from list'... (More)
13 Other Users Have The Same Problem - Continued
Comment by nosmo_king_e, posted on Feb 26, 2009
I had the same problem and by following the instructions of "gbduo" I corrected the situation. The solution posted by Graham (gbduo) is:
Graham
UK
Thank you very much Graham.
Comment by Guest, posted on Feb 20, 2009
Im getting the "validating Identity" msg...when I turn off the authentication box, I get "limited or no connectivity" , so Im basically back at where i began , unable to connect to internet. Any suggestion? Could it be something with the wireless router or my laptop?
Comment by ltrabjr1, posted on Feb 14, 2009
I am having a similar problem with my netgear WNR 2000... when I try to log on with my passphrase and confirm, msg states cannot confirm passphrase, but then continues "validating identity"... any thoughts???
Comment by Guest, posted on Nov 26, 2008
When trying to connect to Belkin wireless the status keeps saying validation and the icon says Windows unable to find certificate to log on to Belkin.
Comment by john900, posted on Aug 08, 2008
Same problem validating identity with Belkin router and windows XP
Comment by dm17, posted on Jun 19, 2008
I have the same problem the below solution did not change things:
" Try disabling your adapter, then go into internet explorer, tools, internet options, content tab and click "clear ssl state". Now, re-enable your adapter and it should now connect."
Comment by Guest, posted on May 08, 2008
I also have a laptop connected to a wireless belkin router and under status it says validating identity. I have also tried the clear the ssl state. I can get on to the internet but I keep getting the validating identity message. What does this message mean and how do I get rid of it?
Comment by Guest, posted on Feb 24, 2008
I have the same problem. I tried the suggested fix (disable adapter etc.)and it didn't work. Any other suggestions????
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Belkin Router:
Top Router Experts
Rank: Guru Guru
Solutions: 1451
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
