Question about Tilia FoodSaver VAC420
Can you purchase a replacement seal/gasket for the Foodsaver vac420
    Novelist:
  • 88 Answers
I posted this solution for other problems - it might help you, too:
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
SOURCE:
Trying to find a gasket for ......food saver vac 820
Replacement parts for the Tilia Foodsaver products can normaly be found here:
http://www.foodsaver.com/parts.aspx?search=420
However I am having trouble with your model number. Are you sure it is correct?
Suggest you inquire with the company as to which listed model would be compatible with your model . You may contact them over the web here:
https://secure.foodsaver.com/contactus.aspx
Aug 14, 2011 | Tilia FoodSaver VAC420
The Vac runs and runs but does not seal. Can you order a replacement seal unit in Canada and where?
Practically speaking, before you start thinking about spending money on replacement parts, please visit here:
http://www.foodsaverblog.com/
You will see a comprehensive list of models and prices.
Then you can decide what to do.
You can also check here: http://www.foodsaver.com/Index.aspx for your nearest retailer of parts and supplies.
May 23, 2011 | Tilia FoodSaver VAC420
I am on my 2nd foodsaver. My 1st one stopped working, which I later found out, was probably due to the bottom gasket. My 2nd one had the same problem. I called FoodSaver, and they suggested that I flip...
I replace my gasket with a piece of 3/8" Poly Foam Caulk Saver (found mine at Home Depot - @$2.00 for 20'). It's a snug fit in the gasket groove. Cut long enough so that the ends touch tightly. It will create a good air seal and works well.
Feb 14, 2011 | Tilia FoodSaver VAC420
I have a Tilia Foodsaver Bagvac 35-0500. Are ther replacement parts available for this model?
Write to customer service. Company is now owned by Jarden Inc.
http://www.foodsaver.com/Support.aspx?id=sfaq&fgid=21
Oct 27, 2010 | Tilia FoodSaver VAC420
Not sealing
I have the same problem on my V2490. Will not heat to seal or create bags. So I took it apart! The heating element is only heating at the ends. Since Tilia doesn't repair or sell parts, I found a cite that carries replacement items.
www.elementandteflon.com/product/HE-14-FS
I don't know how if a replacement element will help. I am trying to find a wiring diagram to make sure i do it right...
Sep 19, 2010 | Tilia FoodSaver VAC420
My foodsaver Vac 420 Vacuum Sealer won't heat and seal the bags.
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Mar 29, 2010 | Tilia FoodSaver VAC420
Vacuum on foodsaver II seems to have slowed down or quit working any suggestions? and at times seal doesn't work. any parts source?
The Foodsaver gaskets will deform and/or dry out with time, just like in any device, and this will result in no vacuum or a very slow process, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Feb 26, 2010 | Tilia FoodSaver VAC420
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
Need to get the bottom seal/gasket, foodsaver no longer has parts for this model. Do you know where I can get one?
try using a small bead of high quality,high tempature silicon caulk. put bead over existing seal and make sure it cures thoroughly before closing or you will never be able to open it
Jul 21, 2009 | Tilia FoodSaver VAC420
My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Dec 30, 2008 | Tilia FoodSaver VAC420
Tilia FoodSaver VAC420 Logo
573 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
elementsandt
Level 1 Expert
Sheldon Dedek
Tim Doolittle
Tim Doolittle
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
