Question about Rotary Hilti Te50 Demolition Hammer Drill Chipper
I need to buy a new handle with depth gauge for Hilti TE 50
I need to buy a new handle with depth gauge assembly. Where can i get one?
    Guru:
  • 1,326 Answers
Hilti.com
Posted on Dec 10, 2009
Where can I get a new side handle for my hilti te 2s
Try http://www.hilti.com/holcom/page/module/home/home_dispatcher.jsf
Jun 22, 2012 | Dewalt Hilti Te 2 Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Need a replacement depth gauge and handle for a te7c
go to Hilti.com or call them direct at 1-800-879-8000 to order the parts.
Nov 22, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Service light
You can reset the light. What you need to do it remove the handle assembly from body of tool. The contacts will unplug. Then plug the cord in and pull the trigger and sometimes the light will blink, while holding the trigger in the on position unplug the cord. reinstall the handle and the light should go out. Sometimes you have to pull the trigger while plugging cord in but this should work. and then while holding unplug cord.
Sep 21, 2009 | Hilti Drills
Hitli te 905 avr. light is on. any idea what it
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 16, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Trying to drill a solid concrete 10 inch wall
the ideal sollution is to fully service the machine but there may be a quick fix.
remove the 4 screws that hold the black plastic handle assembly, and take the handle off. on the top of the drill you will see an oil filler cap. unscrew using a 10mm allan key.
empty out any old oil. rinse out with some parafin if you like. empty out again . put some new oil in and replace the cap. 50cc of transmission fluid / power steering oil will do the trick. if this dousnt fix it then you will need to replace the o-rings on the pistons, if this is the case, drop me a email and I will send you a parts diagram. paul@wysehire,gi
good luck.
Jun 02, 2009 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
Rotary Hilti Te50 Demolition  Hammer Drill Chipper Logo
292 people viewed this question
Top Rotary Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Hammering Expert? Answer questions, earn points and help others
