Question about Nokia 6131 Cellular Phone
Phone will not turn on
Took battery off, put battery on, fully charged, now reads "local mode" and although I press the power button, phone will not turn on. Help! Thanks!
  • 1 more comment
  • Magpie01
    Magpie01 Jan 23, 2008
    it happen on FV Update
  • Anonymous Feb 21, 2008
    same local mode problem...
  • Anonymous Mar 04, 2008
    phone just shuts off and then takes time to turn after switching the power on button several times. tried removing battery, same problem
I did and they told me i will cost 160$ to fix it so i will trow to rubbish and never buy Nokia any more this is my second phone went dead.
No Cheers Nokia.
Posted on Feb 22, 2008
  • 87 Answers
There is problem inside ur phone for which is causing "local mode" u should take it to technician.
My galaxy r don't open again after the battery drained. When I charged it there's sign that it is charging but I cant open once I hold the power button
I don't have that particular phone, but my phone has a small LED in the front that turns to red when it's in the charger with a fully drained battery, yellow when it's above 20% charge, and green when it's fully charged.
If the phone is fully charged, but it won't turn on when you press the power button, there's probably a problem with either your charger or the battery itself. I suggest replacing the battery, or when it's built into the phone itself visit the store where you bought it. They might know what to do.
Nov 26, 2014 | Computers & Internet
I hit a button on phone, screen went blank, not able to dial. I put in the charger and it is fully charged
If battery is charged and phone is working simply do this: Press the power button for a few seconds, which is the same as the "hang up" button with red ink on it). Voila! It took me serveral days and a number of dealers telling me I had to pend $300 for a new phone before I uncovered this fix.
Feb 16, 2010 | Panasonic KX-TD7896 Cordless Phone
Does my phone have to fully charge before i can use it again?
No, try and remove the battery again. wait a few minutes.
Now replace the battery, plug the phone in, now press and hold the call button which is the on button for 10 seconds and see if it powers up.
Any more questions just ask.
Feb 07, 2010 | Motorola Mobility RAZR V3
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Nokia 1600 displaying local mode
didn't you try another battery?
Oct 16, 2008 | Nokia 6120
My samsung blackjack 2 will not charge. the battery is now totally dead, will not turn on and will not charge even with the wall outlet charger or the computer usb charger. when the phone still had some...
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Jun 09, 2008 | Samsung BlackJack II Smartphone
Phone wont start with charged battery.
The phone software is corrupted you need to reinstall the phone software if your phone is within warranty please give to service center and or get it done on the local phone service center .......................
Jun 03, 2008 | Sony Ericsson K800i Cellular Phone
Phone Wont Turn On
unfortunately, you'll have to do a master reset on your phone. You'll loose all of your data. TO do this.. power off the phone. Then press the center select button (silver button on navigation pad) then power on the phone while keeping the sliver button pressed. You should get a Master reset prompt.. click Yes.
Apr 11, 2008 | Motorola Mobility Moto Q
your firmware is probably messed up a bit - you will need to redo a complete flash - but not with usb cable - you will need proper equipment like JAF - but you don't need to spend $300 for a tool - we can fix it for you for under $30
http://horizonwirelessonline.com
Jan 23, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 Cellular Phone Logo
186 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
