Question about Magic Chef CDB6100 Built-in Dishwasher
Dw wont drain - Magic Chef CDB6100 Built-in Dishwasher
  • magillago174 May 11, 2010
    possible problems plug not removed from garbage desposal drain line plugged unplug disposal from wall remove line from disposal insert knife or simalar item where line hooks to disposal make sure it is open can look into to verify if open lower drain line into bucket and see if water flows out run dishwasher at drain position with hose in bucket verify flow if no flow problem may be plug in drain line check these items let me know good luck ron
  • 112 Answers
Have you recently installed a new garbage disposel? (forget to knock out the plug?) or your pump could be clogged. first thing i would check out is the drain hose going into the sink. i have unclogged problems there.
Posted on Dec 10, 2009
I want to re-route the dishwasher drain hose to the basement under it. That will mean some kind of extension and probably I'll need some advice on how to route it.
I have never had a disposer under my sink, they are not needed.
As long as there is no back pressure and the outlet is higher than the high point of the outlet, it should work.
Jul 11, 2018 | Stainless Dishwashers
Not draining
Is their debris in air gap or in the bottom of the DW, where the drain is screened? These steps will walk you through solving basic DW problems.
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 07, 2014 | Dishwashers
WONT DRAIN AND SHOWS E1 ERROR CODEE
First, use manual and or the device web site to understand the issue. Is their debris in air gap or in the bottom of the DW, where the drain is screened?
Good luck.
Dec 28, 2013 | Candy Dishwashers
My dishwasher wont drain water out
Good luck. Doing the dishes by hand can be so much fun though.
Dec 13, 2013 | Computers & Internet
Did not fully drain and will not turn back on
Might have blown fuse.
Check for obstructions in drain line -- the pumped line from pump under DW to drain. Is their debris in air gap or in the bottom of the DW, where the drain is screened?
Good luck.
Nov 27, 2013 | KitchenAid Dishwashers
Whirlpool dishwasher quite partner 2 push start button the cancel drain comes on wont start cycle
Number 4 is for you. This may be the problem.
Otherwise start here: Is their debris in air gap or in the bottom of the DW, where the drain is screened?
Good luck.
Nov 04, 2013 | Dishwashers
SHY66CO5UC wont drain all the water
Your float might be stuck.
Check on the bottom of the DW basin for an item that looks like a mushroom. Gently pull up on it. Does it move freely?
Check for debris in air gap and bottom of DW basin.
Good luck.
Nov 02, 2013 | Dishwashers
Hi I have had this intake/drain light come on in my Miele G851 SC dishwasher. I followed the recommended instructions in the manual: - clean triple filter, drain pump, and non return valve - check...
Is their debris in air gap or in the bottom of the DW, where the drain is screened? Look for obstructions.
Good luck.
Oct 25, 2013 | Miele Dishwashers
Water not pumped out of dishwasher
To cut a long story short, lower the drain pipe as close to the floor as you can. Some dish washers have a non return rubber which holds the water in the cabinet until asked to drain.Meaning water wont just flow out with pipe being low.(Im assuming the drain pump is operating correctly).Check if this alteration makes any difference.
Nov 13, 2009 | Dishwashers
Ge nautilus/dw
it sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
Magic Chef CDB6100 Built-in Dishwasher Logo
165 people viewed this question
Top Magic Chef Dishwashers Experts
jeff5may32
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
