Question about Motorola Mobility RAZR V3m Cellular Phone
Phone say battery is chargering but not one bar came one the phone also when i turn it on the phone jumps i cant text or send a call
Tip
Phone Cannot Send or Receive Calls and Text Messages: A Simple Electronic Glitch
It is frustrating when only your phone cannot send text messages no matter how strong the network signal is. Sometimes you feel nobody cares about or remembers you because nobody calls or texts you but actually there are. Your phone just can't be reached or can't receive text messages. When these happen, turn off the phone; remove the battery and then the SIM card. Insert the SIM card to another phone and try sending text messages; if you still cannot send text messages, remove the SIM card and let it sit off the phone for at least fifteen minutes then insert it gain. You should be able to send text messages after that, but make sure you have credits.
The next thing you should look into is the phone. Make sure network signal is present then insert a known good SIM card in your phone and try sending text messages. Reset the phone if you still cannot send text messages, but back up important files and data, such as contacts, videos, images, and messages, before doing so.
One simple way to "reset" the phone is by removing the battery and letting it sit for at least fifteen minutes. Another way is by restoring the phone settings to factory settings. Simply navigate to settings then phone settings and select "restore to full factory settings" depending on the brand and model of the phone.
This tip is not intended to solve virus or firmware problems but rather to avoid unnecessary visit to the service center and save few bucks from a problem only caused by a simple electronic glitch. Check the network signal strength and your credits before jumping into any conclusion.
on Apr 06, 2010 | Cell Phones
Unable send text messages
Have you tried turning your phone off, remove sim card and battery, and then put them back and restart your phone.
Jan 31, 2014 | Nokia C5 Cell Phone
I can recieve text messages but cant send them
there are several reasons why you can't send a message, here are several options that you can try:
1. if you are a prepaid user, make sure that you have enough credits left :) 2. try to reset your phone by turning the phone off, removing the sim and the battery and wait for a few seconds before turning the phone back on 3. make sure that the call barring is deactivated (go to your settings then call settings, call barring, cancel all) you may be asked for a password try 1234 or 12345 or 0000 (as these numbers are set as default pin) or you can try to contact your service provider for the default network pin 4. you can also check your sms centre number and try to change it (for this you need to call your service provider to ask them for the sms centre numbers that you can use) save it, then do step number 2. then try to send a message 5. contact your service provider and ask them to check if your outgoing sms is not barred 6. try to insert your sim card to another phone and try to send an sms using another phone (to isolate if it is a phone problem)
Apr 19, 2011 | LG Optimus Black Smartphone
I recently jumped into a pool with my cell phone in my pocket (SAMSUNG Reality). I realized it 10 minues or so after. Dried the phone. A day later, the phone will turn on when connected to charger...
When phone gets wet NEVER try to turn it on. Take battery out right away shake water off and put both in bowl of rice for at least 24 hrs. If your not home or don't have rice right away take battery out and get some. We have a bowl of rice on the counter all summer long for those who jump in the pool with phone in their pocket. I have washed them dropped them in the toilet my son jumped in pool with his phone, put it rice for 24 hrs and we were up and running with the exception of the one in the pool, that one cost me new battery on Ebay ($4.95) but phone worked fine, didn't even lose contacts or pictures. But the key is to NOT try to turn it on after its been wet. Water and batteries don't mix.
Jun 16, 2010 | Samsung Exclaim M550 Cell Phone
Cant send text messages. Says failed call barred
cant send message and call its says its barred
Sep 27, 2009 | Pantech Matrix Cell Phone
Texts Wont send, then phone freezes
TRY AND RESTORE ALL SETTINGS..ERASE ALL DATA AND SEE HOW THAT WORKS FOR YOU
Jun 19, 2009 | LG VOYAGER VX10000 Cellular Phone
My nokia E71 cant send text messages
yea easy bro, turn off your phone, and remove the battery for 5 minutes. Then hold the 3, * and green keys as you boot up your phone until you see that country selection menu. This is the "hard reset" please note that you will lose all data using this and a back up of important data is necessary before proceeding
Jun 02, 2009 | Nokia E71 Smartphone
Sending a text message on my pantech c150
First, be sure that you are signed up with your provider for send AND receive text messages.
Second, be sure that you are able to see the small "E" icon (or a similar one) beside your communication bars. Sometimes text messages won't send without this full connection.
If both of these are true, then I'm not sure what to tell you.
Aug 21, 2008 | Pantech C150 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
