Screen problems with HDTV lcd flat panal HP TV
My kids were playing a Wii game wehn one of the remotes slipped out of my daughters hand and hit the new TV it nicked the glass but worse the is no picutre only a series of odd lines. I'm sure the impact messed by the LCD's how can I get the screen replaced and is this something that I can do myself.
Thanks
Mary Anne
  • Anonymous May 06, 2009
    i have the same problem
  • 106 Answers
Most likely it'll cost you as much as to buy a new tv.
Posted on Jan 20, 2008
Blue rectangle in lower right hand corner that wont go away
possible bad lcd. bad cof or chip on film. refer local service tech or contact mfg for lcd recall. hopefully its not damage from kids playing wii and one of the hand controls slipped out their hand and hit the screen.
Aug 24, 2011 | Olevia LT37HVS 37 in. LCD HDTV
We had one of our kids accidently have a WII remote hit the screen of our 55" Vizio flat screen. The screen did not break or crack, but when the TV is turned the picture looks like shattered glass. Any...
No,Sorry it a junk tv now.Only use for electronics componnents parts.LCD Screen very tightly control by the TVS industries.Buy a new LCD Screen will cost same as a new tv after part and labors.
Feb 21, 2010 | Vizio VF550M 55 in. LCD HDTV
How to connect a tv to a wii
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
I hit the screen with the wii remote. its damaged
It is obvious that the screen is cracked and must be replaced. There are a few problems in doing that. First, it is NEVER covered b warranty. Second, the LCD panel likely cost at least double the price you paid for the TV, if it is even available. Many are not available. Time to shop for another set. Sorry; John
Feb 06, 2010 | Samsung LN40A550 LCD TV
My Samsung LCD 1080P LCD screen is damaged. How do I replace it?
You are better off buying another TV. Screen usualy costs more then a new TV. It is not an easy job. About 2hrs for a decent tech. Screen for a 37" is about $600-700. A sony....$1300 new sony 799. Best is to sell it for parts. You may get $50-100 for it. Sorry for the bad news. Best to put the WI away/or play nice :). Hit by Wi remote 60% of broken screens ,20% P'd off wife/lover, 10% bad football game,8% kids/bird/pet,2% installer error.
Jan 15, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Wiimote hit my 42" lcd can it be fixed?
The LCD panel which is responsible for the picture is toast. You will need to replace it. You can have it repaired using a TV Repair guy but often it costs as much as a brand new LCD.
I recommend just finding the best sale you can and buy a new one.
My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Sep 08, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My daughter hit the 37" Vizio screen with the Wii remote
Sorry, it can't repaired.
( Secret way of getting it fixed )
Use the Vizio warranty. Just don't tell them about the Wii remote. :)
Jun 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Cracked screen on 46 inch lcd sharp aquos
hi you looking at 1400 for just the screen if you had your tv less than a year then you are covered for one year by sharp so what i would do is call sharp and see if your covered on cracked screens
Jan 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
409 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
