Question about Minn Kota GPS
How do I remove the prop if the shafe just spins
How do I remove the prop if the shaft just spins as I try to take off the nut.
How to remove crank shafe gears
Your Might Max has a 4G60 series engine, so I guess you want to get the 14mm nut off the oil pump belt pulley. On the lower side of the block there's a 17mm (or maybe 14mm, I forget) bolt. Remove this and you can poke a 10mm screwdriver into the hole. This locks the oil pump balance shaft. You will need to rotate the oil pump pulley to get the screwdriver all the way in. You should then be able to remove the 14mm head bolt(it's an M10 I think) on the pulley. It should not be excessively tight.
Nov 16, 2014 | 1994 Mitsubishi Mighty Max
How to remove propeller from 2007 40 hp mercury out board
REMOVE LOCKING TAB, UNBOLT NYLON LOCK NUT...DISCARD!
PROP SHOULD SLIDE OFF OUTPUT SHAFT...IF NOT PROP IS FROZEN.
IF IT A THRU HUB PROP, AND HAS A RUBBER SHOCK ABSORBING DEVICE...YOU CAN'T REALLY HEAT IT..YOU DEFINITELY DO NOT WANT TO BANG ON THE PROP(SHAFT AND BEARING DAMAGE)
SOMETIMES THE PROP HAS TO BE CUT OFF...REQUIRING A NEW PROP!
TIP: IF THIS IS THE CASE:*** ALWAYS COAT PROP SHAFT WITH ANTI-SEIZE COMPOUND WHEN INSTALL A PROP!!!!!
Jul 15, 2013 | Boating
Stuck plastic prop
Once You Have Removed The Nut And Lock Washer ,
Then You Will Have To Get A Puller To Pull It Off ,Or Lever It Off,
There Is No Other Way It Has Probably Coroded And Stuck To The Shaft,Spray Release Oil On It ETC.
Good Luck
Apr 01, 2013 | Boating
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Gear alignment on outboard motor
When the gear box ix in forward, it should make a ratcheting noise when rotated forward and should not turn at all when turning in reverse (or be resistant as your back spinning the water pump -don't do that) Once in gear (forward ) you should be able to mate the shift to the motor. I have removed the prop and nut and used a remote start to spin every thing together, but requires a lot of safety precautions.
If you are working on an older mercury, that shift rod can work both ways with disastrous results if you over spin the shifter to the back side of the detent.
Sep 17, 2012 | Boating
How to remove the prop
there is a plastic nut that screws onto the prop shaft and needs to be unscrewed. there is also a metal pin that goes through the shaft that needs to be in place and in the right position when you replace the prop. make sure you clear out any fishing line etc that may have collected behind it when you change props.sually recommend you put a little clear silicone grease on the parts as you assemble them as well.ake sure you disconnect the power leads from the battery while your doing this to avoid injury.
May 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
The prop will turn on my minn kota endura 44 but it has no power is there a shear pin on this motor
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
May 04, 2009 | Minn Kota Endura 30 Freshwater Transom...
Trolling motor will not spin with out being turned by hand.
Take the prop off and make sure the pin that goes through the shaft is in place. The prop could also not be sitting on the pin proper.
Nov 29, 2008 | Humminbird 575 Fishfinder
GPS Logo
24 people viewed this question
Top Minn Kota GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
