Question about Whirlpool Duet GHW9150P Front Load Washer
What dose the cleanout look like there is a white tube looking thing with a cap but I am not sure if it is it
  • 112 Answers
That is probably it. have a rag ready to catch the excess water. unscrew it with your hand and pull it towards you.
Posted on Dec 10, 2009
SOURCE:
How can I be sure my problem with my 1991 Nissan pickup is oil mixing with coolant
Remove oil filler cap which is normally on top of the rocker cover look at underside of cap, the side that goes into rocker cover, and if it is covererd in a white oily substance or if the tube that the filler cap goes into has the white gunge in it yo have oil and water / coolant mixing in your engine
Mar 11, 2015 | 1991 Nissan Pickup
2004 gmc savana is overheating
First are you sure the thermostat was installed correctly if so you have to have a blockage it could be that your new thermostat is bad it dose happen but again you sure the t. stat is not up side down dose your heat blow hot? probly not if lower hose is cool only thing left is the radeator is pluged look in it at cap do all the ports look open its posable your air locked you should have a bleader valve may be on or neat t.stat or on intake open itand run you can leave rad cap off or louse if at 200% its not sirculating i would pull t. stat out and run it with out one just as a test
Apr 19, 2013 | Cars & Trucks
I have a whirlpool wfx9050xw00 it seems to have eaten a credit card and drivers licence....found part of card in the cleanout tube under the front ..but , how do you take machine apart to find other
Sounds like a case of identity theft! :)
Remove the hose from the tub to the pump and check there. Also, reach up into the tub to see if you can fell anything.
Dec 02, 2012 | Whirlpool Washing Machines
Occasionally will not dry clothes no matter how long the cycle continues. Have tried to cleanout the duct and tighten the exaust tube, but nothingworks.
have you tried disconnecting the vent tube and drying a load of clothes, as the vent maybe restricted. Hope this helps Tim if not post again
Apr 15, 2011 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Whate dose the pump cleanout look like
after removing the lower front cover----the pump is right in front. follow the hoses from the bottom of the tub to the pump. have a rag ready to catch the water. unscrew it with your hand and pull it twards you
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cooling fan in Honda
On my 1996 Accord (4cylinder), this was caused by a tube inside my radiator overflow tank dropping off into the tank - the radiator would have too little fluid in it, so the fans would run a LONG time after shutting the thing down. The tank is in the front left, a white cap with a black tube running out of the cap to the radiator. Underneath the cap there should be a foot or so of hose - this is what fell off of mine.
Hooked it back up, made sure enough fluid was in the radiator, and no more problem.
The dashboard coolant heat gage will show the high temperature, also.
Jul 02, 2009 | 1996 Honda Accord
Need directions to unclog my Whirlpool duet washer which is giving me a f21 code.
Empty the washer and get some towels...
  1. Unplug the washer.
  2. Remove the kick panel 4-8 screws along the bottom with a Torx 15 screwdriver.
  3. Directly in front of you will be the pump and the cleanout (large twist-cap).
  4. Pack towels under and around the cleanout.
  5. Turn the cap counter-clockwise and pull out.
  6. Remove any debris.
  7. If you have an additional cylindrical pre-filter, remove and clean it.
  8. Re-assemble.
  9. Plug in the washer
  • Note: If you see bubbles or foam in the cleanout, you're using too much soap.
Dec 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Frontloading duet HT retaining water in the tub
THE ONLY THING BETWEEN THE TUB AND THE DRAIN IS A
PUMP/MOTOR AND CONNECTING HOSES. THERE IS ALSO A CLEANOUT BEHIND THE FRONT LOWER PANEL. REMOVE THE PANEL BY REMOVING THE THREE SCREWS ALONG THE BOTTOM EDGE. PULL DOWN ON THE PANEL TO REMOVE IT. A LARGE CAP ON THE FRONT OF THE CLEANOUT CAN BE UNSCREWED TO REMOVE A FILTER.
CLEAN IT OUT AND INSPECT THE ENTRANCE INTO THE PUMP HOUSING. MAKE SURE IT IS CLEAR. REASSEMBLE AND CHECK OPERATIONS OF THE WASHER.
Aug 01, 2008 | Whirlpool Washing Machines
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Whirlpool Duet GHW9150P Front Load Washer Logo
23 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
