Question about Whirlpool GC5SHEXN Side by Side Refrigerator
Center Column is getting hot
My center column is getting hot as described with the Frigidaire FRs23H5AS. Are they the same refrigerator? Tried replacing the compressor fan, but still gets hot. What's next?
  • Mike Smith
    Mike Smith May 11, 2010
    Did you clean the coils in front , behind the bottom kick plate ? Either dirty coils , or , a bad fan motor , is the cause .
    Novelist:
    Scholar:
  • 100 Answers
Generally that means your auto defroster system is defective. It could be a simple switch/sensor. See if you can find a switch to turn off the AUTO DEFROSTER and see if that solves it. If it does, then you have a sensor problem. If it does not, then you might have a short in the system and it would be advisable to have a certified technican look at your unit. If it is a short and it is in the walls, then you are probably S.O.L and might have to disable the defroster and live with it and just be required to manually defrost your refer unit it truly dies. Reason being, if it is in the walls, it is cost prohibative to open the walls and repair a refers wiring, tubes and other components in the foam and such. Sorry for the tough news. Lets hope the techincan you have come out finds a cheap easy fix for you.
Kindly,
Posted on Dec 10, 2009
Water/ice build up in center column of fridge
clean the backside fins of the fridge..they get gummed up with dust and cannot cool the water effectively..clean inside and especially outside back and bottom..also..defrost it fully first..
Jan 08, 2014 | GE Refrigerators
Front Center wall getting hot to the touch On Frigidaire side By
Normal operation to reduce outside condensation.
Could get up to 120 degrees.
Jul 04, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Center Column is getting Hot
check the condenser fan motor to see that the one that you changed is running in the right direction some run clockwise some run counter clockwise
if it is the right direction check the condenser for lint buildup
and if needed clean the coil
also check the evaperator for an ice and frost build up that can ocurr when the condenser fan goes bad
normaly the buildup of ice or frost will be on the top of the evaperator coil
just use a hair dryer to remove if needed dont pull on the ice if found or use a screwdriver or knife heat only to melt
Jun 10, 2008 | Refrigerators
Rs2630ww
You should be able to see the fan spinning if you look under the frige with a flashlight to the back or feel air flow (tissue paper helps) coming from underneath it. As for the center column, if you mean the divider area between sides, that being real hot means the compressor refrigerant is overheated. It should be warm to touch not hot. Sounds like your condensor fan is out or packed full of dust bunnies and not spinning. The compressor will overheat and "trip" the thermal overload on and off so you do need that cooling fan. All the underside of the frige needs to be clean and clear of hair, pet fuzz, etc. in order to cool properly. The fan is likely out of warranty but they are cheap and easy to replace by a homeowner.
Dec 19, 2006 | Samsung RS2630WW Side by Side Refrigerator
Rs2630ww
The light for the filter is not a problem. The thing to check is that the fan in the back is running. It should run any time the compressor is running to cool the compressor. If it is, then you need to pull the front grille or toe kick off and look under the fridge. Is there a lot of dust and dirt blocking the airflow? If so, vacuum it out. If not, pull the fridge out and check behind it. Is there a grate clogged up with dust? The reason the divider gets hot is because there is a freon line running through that part of the fridge to keep moisture from forming around the door seals. If the fridge is not cooling properly (dead fan motor or dirt blocked airflow) then the freon in this line gets very hot and all the pressures in the system rise, eventually leading to the fridge not cooling. Good Luck !
Oct 07, 2006 | Frigidaire FRS23H5AS Side by Side...
Whirlpool GC5SHEXN Side by Side Refrigerator Logo
268 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
