Sony PlayStation Portable (PSP) Console Logo
Posted on Jan 20, 2008
Usb downloading when we download some games from laptop to psp we can't find them on the psp after it has finished copying what do we do then?
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jan 20, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
2431
Points
13
You probably dont have them moved to the right location
Sorry i have posted my 1st comment wrong. hi, I have recently bought my Sony PSP 2000 (piano black). It do not play the copy game CD's of UMD. When I bought that copy CD and put in my PSP it gives...
Here try this method.
  1. Open your Psp and Press Select to show the menu.
  2. Now Change the USB Device from Memory Stick change it to UMD Disc.
  3. And Exit the menu.
  4. Make Sure that you UMD GAME in inserted in the drive.
  5. Now insert your usb cable into your computer.
  6. On your PSP , GO to settings and USB CONNECTION
  7. Now on your computer go to MY COMPUTER and Double Click your PSP DRIVE.
  8. Now on your PSP Folder, Copy the game ISO and paste it in your Desktop
  9. Now Download and Install this software DOWNLOAD LINK
  10. Once install, Run this software.
  11. Choose compress ISO to CSO.
  12. on INPUT FILE, Browse for the game ISO, ( We save it in desktop )
  13. on OUTPUT FILE, Select the destination where you want to save the COMPRESSED FILE.
  14. Now choose your compression level ( I Suggest you choose 9 - Best Compression )
  15. Click Compress and wait for the process to finish.
  16. Now lets go back to your PSP, Press Select Again to show the menu.
  17. Now Change the USB DEVICE back to MEMORY STICK
  18. Go to your Settings and USB CONNECTION.
  19. Now on your computer, Open Your PSP Drive.
  20. Go to ISO Folder, (DO NOT CLOSE)
  21. Go to the Folder where you save the compressed file.
  22. Copy the compressed file and paste it in your ISO Folder.
  23. Now go to your PSP and Play the game.
  24. Enjoy.
Goodluck in doing this method. Hope i Helped. Please give me Feedback regarding my solution thanks.
2answers
How to download a psp games for free??????????
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
2answers
How to download from the computer to psp?
3. EXIT USB MODE
1helpful
HOW TO DOWNLOAD GAMES FOR MY PSP
download your like game on your computer if you download it connect the usb of your psp to the computer and pass the game that you download by selecting my computer in start button on your computer then select the iso or cso then select the game that you download copy the game to your psp then you can play your game.
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
2helpful
2answers
How do i download free psp go games
Like many others who had purchased original PSP games from the retail outlets, you will realize that as the games is completed, buying new games seem to be getting expensive and unaffordable. What else can I do if I want to continue to play new or old fashioned games on my PSP console? I start search and looking for website that offers free PSP download games.
Once I had downloaded the PSP games onto my console, how to play PSP download games was my next question. I'm not sure exactly how PSP works when I download new PSP games onto the unit, but I sure have found some answers while I was looking for it. Since I'm facing and struggling with this problem on how to play PSP download games on my unit, lots of other people must be also getting the same problem.
Hope that I get this right for everyone to play PSP download games because I used the same method here to play on my console. Before we get started, I'm using a PSP unit with firmware of 1.5 and having a Sony PSP compatible memory stick pro duo.
Since you are going to download the PSP games, you must download the games for the correct version of firmware, if not it will not work. Newer version of the firmware is available to anyone from the PSP official website. Most homebrew PSP games works with firmware 1.5 and below because the newer firmware upgrade is trying to block people from using homebrew games. Make sure the games you are downloading ends with PSP because only PSP files are compatible with Sony PSP unit.
instruction
  • Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  • To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  • Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  • Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
  • 1helpful
    Download this game
    Hi there Shahzab,
    I would suggest using Torrents to download this game.
    1. Go to Torrentz.com
    2. Search for this game title
    3. Download it using torrent program
    4. Once finished downloading, copy to PSP
    5. Play! enjoy!
    How 2 download psp games?
    • Download desired game from an Internet game site onto your computer.
    • Connect the PSP to the computer using the USB cable. The memory stick needs to be in the console at the time of connection.
    • Copy the downloaded game files into the PSP game path on the removable drive. This puts the downloaded game onto the PSP memory stick.
    • Disconnect the PSP from the computer once the game has been fully transferred.
    • Look in the PSP main menu from the game folder. Scroll to "Game" and select the memory stick option. Press the "X" button to display the list of available games.
    • Select the downloaded game and begin playing.
    Good Luck and have a nice day.
    How to download a game in the PSP?
    Download desired game from an Internet game site onto your computer.Connect the PSP to the computer using the USB cable. The memory stick needs to be in the console at the time of connection.Copy the downloaded game files into the PSP game path on the removable drive. This puts the downloaded game onto the PSP memory stick.
    Disconnect the PSP from the computer once the game has been fully transferred.Look in the PSP main menu from the game folder. Scroll to "Game" and select the memory stick option. Press the "X" button to display the list of available games.Select the downloaded game and begin playin
    2answers
    How can i put hole games on psp for free with no custum firewire
    This is not possible for free, for a low charge you can get alot games from playstation network.
    The original Sony firmware also won't run homebrew software, it will only run the games bought from Playstation Network and original UMD's
    If you want to play backuped game and homebrew, you still have to flash custom firmware on your psp.
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
