Question about Xerox DocuMate 510 Document Scanner
Black Line Down the Middle of Everything I Scan
What do I need to do? I already cleaned the ADF pad. Please help me.
Black line 6130
Are the scan settings correctly specified for the scanning application software used? Check if interface cable are correctly connected.When the error occurs on ADF front, clean the glass inside of Base Unit. When the error occurs on ADF back, clean the glass of the Upper Unit.Check if any dirt get on the white reference sheet?
Also, check the mirror of the OPT Unit dirty, clean the mirrors.
Check the connector and check any cables are damaged,if so, then replace the damaged cables.
If the above doesn't help, then the issue may be due Optical unit or Control PCA problem. hence, you may have to seek the help of Fujitsu scanner technicians for rectification.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Apr 25, 2013 | Fujitsu fi-6130 duplex scanner
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
How do i get rid of a black line that ahows up down the r side of scanned documents, there is no line on the originals
If you are using the Automatic Document Feeder (ADF) to scan, you may need to clean the scanner bar glass.
First test: See if the line appears when you scan on the flatbed. If so, it is probably a hardware failure.
If it appears only when using the ADF, you need to clean the ADF.
HP has a general diagnostic and cleaning procedure here:
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846928&lc=en&dlc=en&cc=us&destPage=document&product=391182&lang=ru
Apr 13, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Black line when using feeder. I have cleaned with alcohol the glass, rubbers, everything, as suggested. Just tried scanner, same line appears.
Determine where the line is...right side, middle, left side. Lift the ADF up. If you have to lay the paper down on the glass and match the line to the glass. There has to be a piece of dirt in that area. Sometimes it helps to gently run your finger of the glass(where the line is). Feel for any abnormality. Try a magnifying glass. There is dirt there. That's the only thing that will cause a black line when using the ADF. Check the underneath of the ADF cover for dirt.
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet 6480 leaves a black line down left side of sheet only when usine document feeder. Already cleaned feeder rollers and feeder glass, as well as glass bed.
I found the following information on the HP web site, under their support forum.
Clean the automatic document feeder (ADF)
If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
Remove all originals from the document feeder tray.
Open the ADF cover.
Lightly dampen a clean, soft, lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the rollers and separator pad.
NOTE: If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
Close the ADF cover.
Step 2: Clean the glass strip in the ADF
Open the ADF cover, and lift the ADF mechanism.
Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
Gently clean the glass strip inside the ADF, and then thoroughly dry it to prevent spotting.
Lower the ADF mechanism, and close the ADF cover
Close the scanner lid, reconnect the power cord to the product, and then press the Power button to turn on the product
Aug 23, 2010 | HP Office Equipment & Supplies
Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
Jan 26, 2010 | Dell 1600n All-In-One Laser Printer
LINE THROUGH THE MIDDLE OF THE PAGE
After making sure all is clean, you need to power off and on again so that the scanner calibrates to a clean glass. If there was something blocking the last time it was powered on it will make streaks until you power cycle the machine.
Jan 08, 2010 | Brother MFC-7820N Printer
Recieving end gets a page with a black line down the lenght of pa
There is a narrow glass on the left of the scanner glass. look at it ,you will probably see a spec of dust,dirt or debris there. Clean it. If it is on the inside of the glass, you will need to remove it and clean it.Also, lift up the ADF cover and clean the rollers with a cloth and some alcohol.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 15, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP 4345 Dark Line in Middle of Scanned Image
The correct answer is to clean or replace the mylar sheet on the bottom of the adf
Mar 13, 2009 | HP LaserJet 4345mfp Printer
ADF not working.
if the black line shows only when you use the ADF, lift the whole document feeder, and look on the very left of the glass (the area onto which the paper is travels from the ADF). Check that the glass is clean in that area.
On the ADF:
Open the small ADF cover on the top right. There you will see rollers and a paper sensor. First make sure the isn't any paper stuck in the rollers. Clean the rollers with a damp cotton pad or cloth a small amount of dish washing detergent. Make sure it is damp. Then check to make sure that the paper sensor lever is working by toggling it. The paper sensor is spring loaded, check that the spring is in place.
Thanks, Joe
Oct 05, 2008 | HP LaserJet 3030 All-In-One Printer
Xerox DocuMate 510 Document Scanner Logo
113 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
