Question about GPX MW3837 MP3 Player
Switch from MTP to USB
It wont switch from MTP to USB when i click on mode. my computer needs it so be on USb i think because the media player says "connect a device" but its already connected. the screen of themp3 player says MTP when it connected to the computer, but the media player doesnt know its connected. how do i switch it?
I had this same problem and was able to solve it. Just go into Control Panel (make sure it's in Classic View)-> System -> Hardware -> Device Manager, right click the GPX icon under Protable Devices and then click unistall. Then disconnect and reconnect the player. Windows will automatically install the drivers and that's it, you can now go into USB mode again. Hope it helps.
Posted on Feb 22, 2008
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
May 17, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
Need to mp3 out of mtp mode and into usb mode need help
in the manual it says Turn on the MP3 Player by holding the PLAY/PAUSE button. 2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer. 3. When connected the LCD Display will either say “USB” or “MTP”. 4. Press the “M” (mode) button to switch between “USB” and “MTP” mode. “MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5 is this helpful.Take your time sometimes these things don't work because you've missed out one step so go slow and try it two or three times before you give up
Aug 29, 2009 | GPX MW3837 MP3 Player
Wont change back to mtp
. On the mp3 player, switch between the Usb and Mtp mode (The M button) on the side of the player.
May 17, 2009 | GPX MW3837 MP3 Player
MY GPX MP3 PLAYER MW3837 WONT SWITCH BACK!!...
Nov 30, 2008 | GPX MW3837 MP3 Player
Will not show songs
This player has a USB and an MTP mode- the most annoying fetaure ever invented on mp3 players.
You can switch your player between USB and MTP mode only if your player is connected to Windows XP machine and Windows Media Player 10. When the player is connected to your Windows XP machine, pressing the M button on your player will switch your player between USB and MTP mode.
-Tha Mp3 Doctor
Aug 26, 2008 | GPX MW3836 MP3 Player
keep it pluged in the usb to the computer then hold the m button down for six seconds then it will switch over to usb
Feb 26, 2008 | GPX MW3836 MP3 Player
MW3837 MP3 PLAYER
push the mtp mode button
Dec 20, 2007 | GPX MW3837 MP3 Player
773 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
