Question about Maytag Refrigerators
Why my refrig will notstay cold . the motor is running,but it is not freezing
  • Mark Egan May 11, 2010
    Very likely a defrost problem. Please reply - 1) Is the freezer section cold, refrigerator section cool to warm? 2) Can you see frost accumulated on the back wall of the freezer section, or inside the louver grilles of the back panel? I will need a Maytag Model number with your replied answers above to provide you with more help.
    Problem Solver:
  • 11 Answers
Gcage,
Check inside of the freezer for frost on the back wall. If you find frost inside of the freezer compartment it usually indicates that you are having a defrost problem. If you can't find any frost in your freezer and you are sure that the compressor is working then your refrigerator may be leaking freon. Lets hope that it is just a defrost problem because freon issues are a bit expenssive to take care of it.
Good luck
Check us out at www.CenturyApplianceRepair.com
Posted on Dec 10, 2009
SOURCE:
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Freezer and fridge cooling but freezer not freezing and fridge not cold enough
Their are a couple things that could be causing that.
The conderser coils under the kickplate below the doors is clogged with dust. Remove the kickplate and check/clean using a refrigerator coil brush that could be purchased from your local hardware store (Lowe's HomeDepot Ace hardware)
The condenser fan motor behind the refrig., behind the lower service plate directly next to the compressor isn't running and needs to be replaced.
Good luck,i hope this helps you to get your refrig back to cold,
Gene
Aug 13, 2011 | Amana ARS266ZB Side by Side Refrigerator
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
Just had a new compressor installed. My refrigerator side by side is too cold. I have set the control to ''factory set'' but still is too cold. Adjusted to lower setting, still too cold, below 30. What is...
check the freezer compartment temperature.should be around zero.if it is around zero but to cold in the refrig compartment you would be looking for a air flow problem,many refigerators have motorized dampers,they sometimes freeze,or break and allow too much cold air into refrig.if freezer is below zero your looking at a control issue
Jan 21, 2010 | Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Freezer is cooling, but refrigator is not cooling
take a look at your evaporator fan motor in the freezer to make sure it is running and not built up with ice around it. this fan motor pushes the cold air from the freezer into the fridge to cool the fridge. you say the freezer is "cooling" , is it freezing??
Oct 14, 2009 | Hotpoint Refrigerators
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrigerator Freezing
Your refrig has a mechanical damper (the a b or c knob) it may be broken (uncommon ) \ is the freezer fan running even if the cold control is cycled?? Other than that it must be a faulty cold control These are very reliable refrigs and your problem is interesting. Please rate my solution
Oct 02, 2007 | Refrigerators
Refrigerators Logo
78 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
