Question about Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
The generator makes a very loud noise from the generator side not the motor side. If I pick up slightly on the housing it stops, but starts again when I let go. Nothing external seems loose. Any ideas? Coleman Powermate 8750 Generator Honda 13HP GX390 engine
    Habit-Forming:
    Scholar:
  • 43 Answers
The main noise source of engine is as follows:
Induction noise
Exhaust noise
Combustion noise
Mechanical noise
Cooling fans noise
For more:
https://www.dieselgeneratortech.com/generator-sets/generator-set-noise-source-and-solution.html
Posted on Aug 07, 2018
  • 211 Answers
Hi
check the bearings,the piston and piston rings,the connecting rod
regards savumihai71
Posted on Dec 16, 2009
The oven has trouble ligting,and make,s a boom sound when lighting
Magnetron
If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Enter your model number to see parts for your microwave.
Help me find my model number
Exhaust Fan Motor
If the microwave is loud when running the fan motor might be
Stirrer Motor
If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor
If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Apr 02, 2013 | Microwave Ovens
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 18, 2012 | Microwave Ovens
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Oct 15, 2012 | Microwave Ovens
Cooling fan makes a loud noise
You may need to remove the blower motor and check for debris in the box, or a failing bearing on the motor.
Sep 25, 2012 | 2003 Chevrolet Monte Carlo
I have a 2003 chevy cavalier. i just recharged the ac but when i put it on high it makes a loud noise. tracked the noise down to under the dash on the passenger side. what is that part called and should it...
THE LOUD NOISE IS PROBABLY COMING FROM THE BLOWER MOTOR WHICH IS LOCATED IN THAT AREA. THESE SOMETIMES MAKE A LITTLE NOISE BUT IF THIS NOISE IS LOUD OR JUST DOESNT SOUND RIGHT, THE MOTOR COULD BE GOING BAD.
Jul 09, 2011 | 2003 Chevrolet Cavalier
My rear wireless speaker from one side is making a loud noise.
the problem is the transmitter. it is generating undesired signal. in all wireless communications if the transmitting end creates oscillations other than which is desired - they are termed noises. ur receiver unit happens to pick up one of those noises and is able to amplify it. a qualified tech will be able to identify the frequency range and filter that out on the transmitter stage. if the warranty covers it- replace!
Mar 12, 2010 | Panasonic Audio Players & Recorders
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Making loud noise, sounds like the fan is off balance when the compressor turns on but could this be a faulty motor instead?
It could be a motor. Make sure the blades are not hitting the shroud. Normally the motor stops working when it goes bad. I have not found one making a noise so loud it was noticeable.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000 Logo
580 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
